What type of oil do you use? (The Mother thread)
Old 12-07-13, 10:32 PM
  #271
Finn
Finn's Avatar
When I went through the diagrams earlier I came across this.
My Euro spec car should have this 15609-50031 oil filter bracket
and US spec a 15609-50010 (05/1989 - 08/1990) or 15609-50011 (09/1990 - 09/1994)
Both versions listed 90915-03005 as original oil filter but aftermarket brands seem to vary.
It looks like the original filter has evolved along the following "path":
90915-03005 -> 90915-20002 -> 90915-20004 -> 90915-YZZD3.
Old 12-12-13, 07:54 PM
  #272
dc893
dc893's Avatar
Thought this was funny and figured it is oil related. It is oil related.
Old 12-12-13, 10:14 PM
  #273
Sc0pe
Sc0pe's Avatar
Originally Posted by dc893
ENEOS Nippon Oil Funny TV Advertisement - YouTube
That was a great success. I kind of want to see what the current commercial is... lol
Anybody here running Royal Purple 5W30? I'm considering rolling with that, and a 20-400 filter, for my next oil change. And also, is a 5qt. bottle good enough for a '99 LS, or should I get another quart to be safe?
Old 12-12-13, 11:19 PM
  #274
LScowboyLS
LScowboyLS's Avatar
based on UOA's, (used oil analysis) most of the serious oil geeks at BobIsTheOilGuy.com seem to like Pennzoil Ultra better than any oil out there, at least in 5W-30 - but it can be a bit hard to find. Toyota has back-specced most of the older 90's models for at least 5W-20, but unfortunately not our LS400's yet. - and no, the oil gurus at Bob's didn't forget to look at Royal Purple in depth! - or Amsoil, or Redline, etc.
if you had a newer car, of course thinner is even better, such as a 5W-20 or even a 0W-20, and in 0W-20 the new Toyota oil seems to ace everything at the moment.
the best weight for long life for our cars is 0W-30, but very limited choices of oils in that weight, German Castrol, being one example.
If you are curious as to why thinner oil is better, head on over to Motor Oil 101 and do a bit of reading up! - very enlightening! - and by the way, the climate where you live, surprisingly, is not a big factor in selecting the oil weight you should be using, contrary to popular belief! (the article explains why)
As far as the best oil filters for the LS400, I put together a nice list of all of the best, after cracking open a couple of dozen, and inspecting the insides - and the bonus is, many are 1 size oversize!
Right now, my favorite filter for our LS400's is, surprisingly, the Motorcraft FL-400S, due to it's superior anti-drainback valve, which seems to get more oil to critical top end engine parts faster than any other filter I have seen on a cold engine, saving wear. This feature is far more critical to long engine life than specs like "so many microns" filtration, as the vast majority of wear happens at startup!
Old 12-13-13, 12:58 AM
  #275
Sc0pe
Sc0pe's Avatar
Thank you for all the informational links! Ironically, my main basis for hearing about Royal Purple ,as a company, was through your post about oil filters, and I happened to like it because it was (named after) my favorite color That aside, most people seem to like it a lot, and rate it well (though that doesn't really tell me anything as far as performance with my car goes) but I'm feeling confident enough about running it on my next oil change. One other mentioned Royal Purple 5W30 in this thread, but that was "years ago", so to speak.
Old 12-13-13, 03:55 AM
  #276
LScowboyLS
LScowboyLS's Avatar
well if purple is your favorite color, then I would definitely use the filter, everyone sees that and it's a very good filter!
as far as the oil, it's very good oil, but not really worth the price, but purple colored oil is kind of cool, to do at least once!
Old 12-13-13, 12:49 PM
  #277
Bill Dowd
Bill Dowd's Avatar
Mobil 1 in everything my 1986 Toyota Cressida went 529,000 plus had synthetic oil in everything nothing wore out 1991 LS 400 over 300,000 miles nothing changed still going strong change trans oil along with ps at 30,000 and engine at 15,000 miles all new LS 460's come with Synthetic oil.
Old 03-24-14, 07:42 PM
  #278
dc893
dc893's Avatar
Just switched over from ENEOS to Pennzoil Platinum made by Shell with a Toyota filter. The new Pennzoil synthetic oils are being made from natural gas.
Old 03-24-14, 07:57 PM
  #279
eld4au6
eld4au6's Avatar
PO was using castrol 5w30 synthetic blend @ 233k, I just changed it to castrol sytec 5w30 with a toyota filter.
Old 03-25-14, 04:43 AM
  #280
blumonster
blumonster's Avatar
Castrol 0w-30. Japan made oil filters are available even now. I have a case of 20004.
Old 03-25-14, 10:35 AM
  #281
LScowboyLS
LScowboyLS's Avatar
0W-30 synthetic and Japanese made filters - now here is a guy who is thinking it through! - good job!
Old 03-25-14, 10:40 AM
  #282
timmy0tool
timmy0tool's Avatar
where can we get a case of 20004?
Old 03-25-14, 11:14 AM
  #283
blumonster
blumonster's Avatar
It was a western Toyota dealer, less than 10 bucks a filter. I think it was Olathe Toyota.
Old 03-25-14, 11:22 AM
  #284
blumonster
blumonster's Avatar
I used a few of these on our Sienna.
Old 03-25-14, 11:30 AM
  #285
blumonster
blumonster's Avatar
LScowboyLS, if I get that car I will keep using the combo is what I meant. 0w-30 Castrol is cheaper through Autozone and OEM filters are usually the best choice, especially the foam type Denso filters.
I use smaller versions of these Japanese filters in my 7afe engine, use 20004 on Sienna. Cheaper than some Fram, Bosch,Purolators. For some reason in WI winters, engines are quieter with this combo.
Quick Reply: What type of oil do you use? (The Mother thread)
