Cigarette Lighter POWER ISSUES?
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I cant seem to get a car charger or any aux charger to work in my 92 LS400. Is this a common issue? i just bought the car 2 weeks ago, and its a pain that i cant charge my phone. I have a lighter outlet in the back and in the front neither work. any ideas? thanks
Check the fuse. It's located by the pedals. I believe there is one fuse per power outlet. The fuse will be called something like FRNT CIG or something along those lines.
I was having the same problem. The fuse was blown, but after replacing the fuse it still didn't work. I ended up having to rebuild the front lighter socket since it had a short due to a failed insulator between the two parts of the socket. It's not too hard to do, I just used a piece of plastic cut to fit where the old insulator was. It could get a bit exciting if someone ever tries to use the actual cigarette lighter, but it works fine for plugging chargers in.
edit: also make sure that the inner piece of the socket isn't touching the outer piece, you might just have a simple short there.
Fuse, mine was out when i bought the car.
There is a link to a tutorial on the only sticky thread in the LS400 forum which walks you through removing the insulator as described by Extrudedco. I did it and it fixed mine
Hey there Scaritto. I checked the fuses by the pedals and there is nothing that I noticed having a name specifically for any component, e.g., FRNT CIG. Is there supposed to be a cover for the fuse box which pinpoints them all? If so it has been gone since I bought the car.
Well there is not a cover there currently and for the owners manual I'm gonna have to contact the person who sold me the car since it was never given to me. Luckily it was a family member I bought it from lol. If all the basics fail to fix the problem then I will definitely take it further and I'll check out the fuse-able link. Thanks for the info. Btw I read in a different website that the same fuse handles both the side-view mirror controls and the cigarette lighters. Is that a fact?
checked fuse and found that its not blown, then opened front lighter as described per the tutorial posted in the sticky thread,
https://www.clublexus.com/forums/ls4...-tutorial.html
but am still confused and don’t know what do we need exactly to replace...!!!
Do we need to replace the nut --->>saw the nut
or the " fuseable link" <<---- what is this piece ?
Can you guys post few photos for the " fuseable link "!!
I need to get this cig lighter working ASAP please!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
My front cig. lighter isn’t working, so
