Replacing struts with OEM, anything else to get?
95 LS with 160K miles. Hoping to restore new car ride with new OEM struts. Like to know what else (mount, springs, bumper, bolts, insulator) to get to really do it right. Also considering Arnott/Strutmaster coil spring conversion kit (cheaper than OEM) but fear they may not be as supple as OEM's. So anyone with Arnott/Strutmaster please chime in. Thanks for any suggestions.
So you have the factory air system in yours?
You can even search for the Arnott discussion.
Like this one a bit further down on the post list down:
https://www.clublexus.com/forums/ls4...tt-struts.html
Plenty of used parts to be had. Unless the springs have seen ocean conditions and or snow-salted roads, they will be fine in the conversion even with high miles.
The 95 I am replacing is regular suspension. Also have a 96 (with Air suspension) that's replaced earlier this year with 4 Arnott rebuilts (Air Shocks). Were just wondering what other parts to get when I order OEM struts. Thanks.
Are you talking about the bump stops on the strut boots or individually that slide over the strut piston/shaft?
These stop the piston from bottoming out in the tube which may cause the valving to be damaged. If the car is not lowered, this scenario is unlikely. If the car is lowered on struts lower than 2", this might occur, also known as blowing the strut out.
My '93 has 235,000km and stock (never replaced I suspect) non-air suspension and it's real wallowy and saggy in the rear so I'm in the same boat as you. I'm going to put up with it as no noises or leaks right now and only paid $2,500 for the car. But if I do replace and I go with OEM I'm quite positive my springs need replaced and I'd be shocked if your's wasn't the same. Keep us posted on how you make out.
My 95 got about 160K miles; mainly southern CA freeways so it's not exposed to too much elements (no salt, no sand, not much rain, etc.); it's not lowered or altered, just hoping to get some of the nice supple ride back. My other ride is a 96 LS with newly rebuilt air shocks (by Arnott) so I am probably pickier with ride.
I am debating between sinking more $ into the 95 or finding a decent 98-00. So trying to figure out how much it would be to get the 95 back to riding/driving like new (bushings, mounts, suspension, steering, etc.). 98+ still command a price premium over 95-97, but sure drive nice.
"Road tested vehicle and vehicle ride is very soft indicating springs being weak. Seems to be sagging and handles poorly"
Can be a number of possibilities in a ride height change accompanied by a soft ride. Bushing wear, dead struts...I would be quite confident that if the springs were removed and tested for load, it would be in spec. Until they are removed and checked against another that type of evaluation is vague. It sure makes the repair bill slant in their favor and the dealers here love to replace parts. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
There are cars at the TORC meets on stock springs that have very high miles...I would be highly doubtful of a spring "going soft". Even in my machine shop days, it was one of the jokes with the heat treat guys about "softening steel". With heat treatment one has to really mess it up and Toyota would not have such issues. Well, I take that back...the 460 had a bad batch of valve springs, but those broke. So it can occur.![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Getting back to these suspension springs...with as many miles as they have now...if the spring heat treatment were poor, we'd be reading many posts about cars really needed new suspension springs. The sprigs in my Celica are 30 years old...for the infrequent times I have driven it, I don't notice a perceptible change.
Better experiment is to replace the coils with new ones and re-install the old struts. I'd take odds it will feel the same. YMMV and it's your $$ if you want to replace.
