tools for rear trans seal replacement?
well, im going to change the rear trans seal as its the only one left at this point i havent changed. things i need to know are, what size are the nuts/bolts that hold the driveshaft to the trans flange? i forgot to check while under there, and once the driveshaft is removed, what size is the nut holding that flange to the output shaft of the trans? i cant take all my tools to my friends house to put it on his lift, so need to know what size sockets/wrenches im gonna need. ive got sockets up to like 32mm and 1.25in. if im missing the size ill need ill buy it so no worries there.
SpinAll4
Performance & Maintenance
10-18-05 11:01 AM
