Antifreeze
Old 11-05-10, 04:01 PM
uwavo
uwavo's Avatar
Exclamation Antifreeze
Lexus dealer claims that the red antifreeze is a MUST or it will damage the motor???? Does anybody has any experience or recomendations about the green antifreeze, it says on the bottle that it is compatible.
Thanks
Old 11-05-10, 05:27 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
they're right. you need red or pink toyota antifreeze.
Old 11-06-10, 01:16 PM
curepunx
curepunx's Avatar
Correct me if I'm wrong...
Red for older models and Pink for newer (2003+) models?
Old 11-06-10, 01:40 PM
RA40
Super Moderator
RA40's Avatar
Compatible but depends on what drain intervals you also desire. Since I swap thermostats about every 30K, I have the system open so it is easier just to use the older mix. Cheap too since a jug of distilled water is $.99 and coolant is shoot, I forget.
My Toyota guy said either but the extended didn't make sense since I will drain off a liter or so for the thermo swap and have to replace it...might as well do the whole routine. Doesn't take very long.
Old 11-06-10, 05:15 PM
uuuuu
uuuuu's Avatar
A gallon of Toyota red coolant (non-diluted) was $26 when I purchased it.
Old 11-06-10, 10:05 PM
RA40
Super Moderator
RA40's Avatar
$26...I don't recollect paying that much. Must have gone up.
Old 11-06-10, 11:09 PM
PureDrifter
BahHumBug
mine was $15-18
Old 11-07-10, 04:46 AM
uuuuu
uuuuu's Avatar
Either that or I got hosed
Old 11-08-10, 08:49 AM
67rivdog
67rivdog's Avatar
What is the difference? If it say it's compatible.
Old 11-10-10, 12:55 PM
lexuslspro
lexuslspro's Avatar
Assuming the car never ever overheats(or has a rise in engine temp) what harm could be done running on low antifreeze?
Old 11-10-10, 02:03 PM
91LS400vgb
91LS400vgb's Avatar
Originally Posted by lexuslspro
Assuming the car never ever overheat(or have a rise in engine temp) what harm could be done running on low antifreeze?
You could get pockets of air in upper parts of the cooling system, which might lead to a blown head gasket or other problems.
Old 11-10-10, 04:21 PM
RA40
Super Moderator
RA40's Avatar
If the coolant level is dropping, there is a leak somewhere. Might be subtle-small but finding out the hard way is and can be $$. If the system is otherwise good, there are two areas I notice with mine:
1. The pet **** on the radiator has an O-ring that after X miles becomes hard. Once you break that initial seal to say do a coolant change, it is often toasted. Replace it at the same time. Common O-ring but I don't have the exact size memorized. I've also broken one due to the nylon/plastic becoming brittle. The whole petcock is like $18 (Which for this part is $$.)
2. The reservoir cap gasket also deteriorates. ~$12
Both inexpensive fixes.
Old 11-11-10, 03:26 AM
Extrudedco
Extrudedco's Avatar
After I picked up my LS400, I later found out the cooling system was maybe half full of what looked like dirty water, thanks to a missing chunk of a well aged radiator cap gasket. The system seems pretty robust.
I can't think of any reason why any antifreeze would be a problem. Just make sure you thoroughly flush the system before swapping to a different one.From what I understand, some antifreeze additives can react with other anti-freezes, (especially when swapping from a propylene glycol based antifreeze to an ethylene glycol based one) so things can get ugly if you're not careful.
gebo
Maintenance
06-09-15 01:06 PM
nthach
Maintenance
02-11-11 10:33 PM
J_LS
02-24-10 03:23 PM
lexus114
11-04-09 12:46 PM
pizitz70
11-03-09 03:30 PM
Quick Reply: Antifreeze
