timing question
1993 lexus ls400
my question is about the timing
if the three marks on the timing belt all align and number one cylinder is at tdc
would it matter if any of the two camshaft gears had been moved during the installation of the timing belt
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
ooohhh
does anybody know where to look for a detailed repair manual on a 1993 lexus ls400
i know ebay has some ,but i want one like haynes
and the actual service manual 2 volume book cost 200 (has anybody bought one does it go into great detail)
something detailed enough that will help me rebuild the engine if i wanted to
ooohhh
Fortunately the engine is non interference so although no physical damage would occur with piston to valve contact the engine would not run correctly and a fault code may be logged as the cam sensor would detect misalignment.
