HomeLink on pre 1998
Old 11-15-10, 07:03 AM
Xaolen
Xaolen's Avatar
Default HomeLink on pre 1998
I have a 1996 with no homelink (garage door opener) and I was wondering has anyone ever swapped the pre 1998 dome assembly with a post 1998? Are they identical except for the homelink? Is this a bolt on or will it require more work; any advise will help especially if someone has done this before.
Old 11-15-10, 02:49 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
most likely not interchangeable but you can buy homelinks from other cars and find a place for them in your car. all the homelink uses is +12v, no integration into the car.
Old 11-15-10, 05:24 PM
Scaritto
Scaritto's Avatar
Much easier and cheaper to just use the clip on ones
Old 11-17-10, 04:53 AM
Xaolen
Xaolen's Avatar
Cool cool thanx for the advice I just wanted to stay as OEM as possible
Old 10-15-12, 01:01 PM
timmy0tool
timmy0tool's Avatar
has anyone ever done this with success, from the last 2 years?
i was wondering this and stumbled upon this thread! i want it integrated like OEM! anything else, i might as well continue using the standard clicker.
Old 10-15-12, 01:30 PM
PureDrifter
BahHumBug
if you have a '95-97 you could possibly try buying the '98-00 sunroof controls and seeing if they swap out?
mitsuman
IS - 1st Gen (2001-2005)
11-17-15 06:45 PM
carlos3366
11-18-12 06:23 PM
duby1
06-24-10 12:21 AM
3rdelement
12-23-05 03:53 PM
George Hsieh
06-16-04 08:24 PM
Quick Reply: HomeLink on pre 1998
