Wheel Fit Question - NEWB!
Old 11-15-10, 02:48 PM
MotoBlack
MotoBlack's Avatar
Default Wheel Fit Question - NEWB!
Sorry - trying to help a buddy out with a wheel purchase and I've searched but can't find exactly what I need to know and this may be easier
Buddy has a 95 LS400 and wants to buy some rims, I found him some Work Euroline DH's in 19x8 +40 O-disk (or whatever Low-Disk is for Work, can never remember) and am wondering if that offset will work or not.
From what I've read so far, it seems a little low for an 8" wide rim on these cars and may be a little too far inside the fender well to look good...could really use the experts advice here!
TIA
Old 11-15-10, 05:49 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
low-disk won't fit on the front brakes of a 95-00 LS400 without at least a 15mm spacer.
search for the wheel fitment thread.
Old 11-15-10, 06:42 PM
MotoBlack
MotoBlack's Avatar
Awesome - thanks for the help. I remember reading the wheel thread a week ago or so but couldn't find it when I searched today for some reason...
Originally Posted by allturbo
WOW +40 is high but you might have problems since its a low disk. 8J is might be a little to sunk in if anything you can always use spacers. I have a 19x9/10 +10 low disk and I have to use a 15mm spacer to clear the front caliper
That's what I was thinking, but with a 15mm spacer...we should be far enough out where it doesn't look bad and he can still put some tall-ish rubber on to help keep the ride smooth!
Anyone else running a similar setup? Tips? Advice?
Old 11-15-10, 07:33 PM
BLKonBLK98
BLKonBLK98's Avatar
best advice was to check the wheel fitment thread. you have tons of wheel/suspension specs to work off.
but the specs you listed are weak to the point of "wait for something better".
marus
08-30-17 07:29 PM
YanoYano
Suspension and Brakes
06-09-15 03:50 AM
MrSlopra
13
01-10-13 06:46 PM
CptnTonus
13
05-06-07 04:45 PM
Quick Reply: Wheel Fit Question - NEWB!
