double checking ucf10 brake upgrade
Ok did my research, wanted to double check.
I have a 1990 ls400 and in order to get the 1995 -97 brakes and rotors to fit on my car need these items.
1995-97 lower ball joints
1995-97 brake rotors
1995-97 calipers loaded with hardware and pads
19x9 wheel with the offset in the 20 range.
am i missing anything?
you don't need the lines, but they are a "while you're at it" upgrade (especially when compared to aged rubber lines).
i have an almost complete powdercoated brake upgrade for sale with very low miles. all you need is the lbjs. lmk if you're interested.
Retired
dont know if SS lines actually help but their better than the 21 year old hoses. check your junkyards for some cheap sets.,www.car-part.com then just hit up r1concepts.com for rotors and your set. i also recommend EBC red pads, had them on my setup and worked perfectly.
also just found some for 63 each with pads
