ls rear air suspension
Hey guys... im new here so bare with me. i just inheritated my dads 97 ls400. well my question is.. the rear air suspension one side is higher then the other n when i rear the rear end right is about 2-3 lower the the left. i also want to lower the car about 2-3 in the front n low as i can in the rear. i wanna put 20'' wheels staggered can you help me with the specs on that also. thanks a million..................Fre
stock air suspension right ? there are rear sensor rods under the car (look from the back) and you SHOULD see it, its quite easy to adjust. drop the thin bar down to your likings. Oh, and you can do the same from the front to get it to the height you want, just know that you'll be putting more wear and tear on the struts.
