Double Din Question
Double Din Question
Yes I searched.....
Was ready to purchase this Double din from sonicelectronix.com and it asked about vehicle compatability, told them I had a 94 LS 400 and it said it wouldnt fit. I have seen plenty of double din's in ls400's. My question is: does anyone know the max dimensions for a double din in a 94 ls400? I am wanting a 7" monitor. Any help would be greatly appreciated. Also has anyone used the double din dash kits on ebay? They are only like 12 bux.
Thanks
Thanks
Im a little confused on this whole metra / beatsonic thing. I just ordered a pioneer avic z120bt and not sure which one to order. From what I read it says that if i want to keep my factory amp / sub I should use the beatsonic, but if I change those 2 out it will allow me to use the metra kit. Which by the way is way way cheaper than the beatsonic. Is this true?
Because I'm planning on changing the sub/amp anyways
k, so no fitment issues I need to worry about? I will go ahead and order it then. Also my rear speakers just quit working im hoping a new deck will fix this. The sub still works just no speakers in the rear.
your factory sub will not work anymore unless you buy the beatsonic adapter (and even then only if you have the pioneer, no go for nakamichi).
the beatsonic dash kit looks 1000x better than the ebay, but they both work. i realize both pics aren't double din but the cheaper kits are all of similar quality.
you can buy the beatsonic dash kit w/o the adapter if you plan on running aftermarket amps/speakers.
Can you hook a brother up with a link for the beatsonic adapter ( looking to go as big as possible screen for 91 celsior) thanks soooo much for any info and links....
guccijon
02-04-10 03:24 PM
marcuse
10-21-08 09:46 PM
FSUnoles
01-09-07 07:59 PM
