Rear wheel bearings
Old 01-12-11, 11:20 AM
vinegaroon
vinegaroon's Avatar
Default Rear wheel bearings
How difficult is it to replace a noisy rear wheel bearing on a 1993 LS400?
Old 01-12-11, 12:10 PM
steve2006
steve2006's Avatar
It depends on your mechanical skills,your tool set and whether you have access to a press.
Personally I would remove the hub assembly then take it to a local engineering facility to have the bearing removed and the new one pressed in then reassemble onto the car.
It's not that difficult if you know what you are doing a good service manual will help.
Old 01-12-11, 06:37 PM
trukn1
NELOC Mod
trukn1's Avatar
Wheel bearings have to be pressed in. Can be a difficult job for the "backyard" mechanic to achieve if not throughly versed in mechanical skills.
Old 01-12-11, 10:01 PM
vinegaroon
vinegaroon's Avatar
Several years ago I used a diagram that I obtained online to dissemble and change a front
wheel bearing on my Lexus. I did have the new bearing pressed into place by a profession-
al. Is it any more difficult than that?
Old 01-13-11, 05:19 AM
trukn1
NELOC Mod
trukn1's Avatar
Should be about the same if you have done so before. This should help you alot,,
www.lexls.com
Old 02-01-11, 02:09 PM
sethjon
sethjon's Avatar
Not to mention if you don't put it in right.
patsc300
Suspension and Brakes
13
02-28-16 05:04 AM
LEXZILLA
08-19-13 10:01 AM
tyncobb
Maintenance
08-17-09 09:25 PM
Quick Reply: Rear wheel bearings
