dianose help
Old 01-19-11, 09:23 PM
Dtwillis5
Dtwillis5's Avatar
Default dianose help
94 ls400 I did the steps for diagnosing the check engine light but I can't get the check engine light to give out codes. What could be the problem have anyone had this problem before.
Old 01-20-11, 07:23 AM
86lumbee
86lumbee's Avatar
Make sure that u r jumping the terminals e1 and te1 under the hood and turn the ignition switch on if this does not work make sure that the bulb isnt burnt out
Old 01-20-11, 07:37 AM
deanshark
deanshark's Avatar
Is the light working at all, does it come on when you turn the key before starting the car? If not, either the bulb is burnt out or someone has covered it with tape. This, http://www.lexls.com/tutorials/intro/codereading.html , is the correct way to diagnose. If there's no codes stored it should continually blink every .25 second.
Old 01-20-11, 09:29 AM
Dtwillis5
Dtwillis5's Avatar
Im jumping the right terminals I have the repair manual. It blank fast .25 sec once before but something wrong with the car because it kill when I press the gas at 1700 rpm
Old 01-20-11, 06:11 PM
86lumbee
86lumbee's Avatar
sounds like you have either an airflow problem or a possible bad coil. but first thing is first you need to make sure that your check engine light comes on when you turn the ignition on and if not you need to make sure it isnt covered.
Old 01-20-11, 07:55 PM
Dtwillis5
Dtwillis5's Avatar
The car been sitting for 2 years. imma clean the throttle body and do a full tune up this weekend. Good looking out imma let u know how it went
Old 01-20-11, 08:43 PM
deanshark
deanshark's Avatar
Maybe it's just not reading a code, it happens. Does the RPM go higher if you give it light gas? Check your AFM to see if it's in spec, mine isn't and it doesn't throw a code unless I unplug it. You have the manual, it will tell you all the specs. When you do the tune up you should also change the ECT. https://www.clublexus.com/forums/ls4...read-this.html it will help ya out with the fuel.
Vinaya
01-15-24 07:59 PM
SC400slide
Performance & Maintenance
07-03-12 10:37 AM
Chris10
07-09-10 07:11 AM
ckh1272
04-22-08 12:45 AM
sc400 2nv
04-09-08 05:50 AM
Quick Reply: dianose help
