Removed Wood Trim Around Shift Now No Power
I can't believe I was so stupid! I am 70 year old female on a fixed so I try to do my own car and house maintenance. I have a 1999 ls400 I bought used. The cup holder has never worked properly because of debris surrounding the mechanism so when it is used drinks frequently spill.
I partially removed the wood trim around the shift in order to clean around the cup holder. I can't believe I did this because I know better but while I vacuumed and cleaned with a wet cloth the ignition was on. To get the trim off I had to put the car in gear and the alarm indicating that keys were in the car was driving me nuts so I turned the ignition on.
I stepped away from the car for a few minutes and when I returned I had no electrical power.
It is as if the battery is totally dead. I am praying that I didn't fry something and am hoping I just pulled something loose!
Any help would be very much appreciated.
Warm Regards, Carol
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Warm Regards, Carol
I dont know what to tell you... but I dont think it is serious. now.. have you:
put it back in park, removed the key from the ignition, close the doors, (I am just trying to start all over) now put the key in, do your tilt & tele. work, or anything? door locks, interior lights? your battery could be just drained. sometimes it dosent take much... give that a try. you might even have to loosen your negative battery cable for a few seconds and let the system reset its self. keep us posted..
Wow Billy, Thank you so much for the quick response. Absolutely nothing works. It is a brand new battery so I don't think it is drained. I will try resetting as you described. I will let you know. Thanks
Just finished screwing everything back together and the cup holder works great plus I didn't lose any screws unless you count the screw loose I have in my head!!!!
Thanks again
Thanks again
Lexucan
14
05-10-10 12:32 PM
mel's-gs
Automotive Care & Detailing
02-07-07 10:27 PM
