Anything Wrong?
Anything Wrong?
2000 LS400
Temp gauge only goes up about 1/4 of the way. Cars runs great other wise. Anything possibly wrong?
Does it take longer then normal to get to the 1/4 mark? If so check your thermostat to see if it is stuck open.
If it takes the same amount of time to get to the 1/4 mark as before, but just stops and doesnt increase anymore. Check the single wire coolant temp sender.
Also check if you have a bad fan clutch that is always engaged.
Maybe the gauge.
My 96 LS 400 did that too.
I didn't do anything to it initially. The car ran fine as well like yours.
After having a chance to change the gauge with retired car parts, it now reads normal.
So, it might be the gauge.
KC98LS
25
03-22-22 03:28 PM
Jlacck
32
02-25-15 06:32 PM
