Hi Performance LS400 mod... in the works!
#31
just found this thread and after changing my air filter over the weekend i have a question...
With that opening to the left, are you not worried about water getting in during driving in heavy rain conditions?
#32
JBrady,
Nice work! I had my 94 apart the other day & my mechanic wanted to mod the intake past the AFM in the portion before the Throttle Body.
On my 94 there is a hushbox with a rectangular opening beneath the intake conduit.
I would buy the heat shield from you if you decide to go into production.
#36
Another angle on the modified housing. Notice that I retained the rectangular cold air intake insert retainer to hold the factory air feed box. This is a good source of cold air and serves several functions including sealing the engine compartment and a partial heat sheild for the air filter area. Also notice I retained the front mounting bolt bracket on the front of the housing. This supports everthing as factory and should be kept.
#38
I know this is an old thread but I would have to see dyno results back to back before I hack up my intake. I doubt it makes any more than 5 horsepower. Until I see dyno numbers this is just another free mod to make cool noises!![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
James
James
#39
#41
It physically does NOT fit into the LS' engine bay, there isnt really anything more to add there. the 2LS actually has a SMALLER (lengthwise) engine bay than the 2GS because the GS engine bay was designed for a 2JZ inline 6, which is several inches longer than the 1UZ.
#43
Wow, back from the grave...
I tested this at the racetrack back to back with a stock cover running 4 passes each way with a 1/2 mph increase in speed which is a clean 5 rwhp.
The GS400 uses a square/rectangular filter where the LS400 uses a round filter with more total filter area. The OEM LS400 filter is the best filter I am aware of for our cars, MUCH better IMO than the K&N as that has substancially less filter area.
Painting the parts with heat reflective resistent paint can't hurt.
Make certain to create good foam heat sealing parts.
I have driven my car this way for 100k miles at times in HEAVY rain and never had any problem. I think the shape of the headlight area blocks most of the water.
