Subwoofer Replacement Ideas?
Old 02-08-11, 05:07 PM
bornpeace
bornpeace's Avatar
Like i said, the volume will be too low from that kicker speaker. You have to find a way to increase ohms, as you know there is no way to control oem amp without messing up ur mid and high speakers. You may want to buy a small amp to push it.
Old 02-08-11, 05:12 PM
p.hase
p.hase's Avatar
not true at all! you must DEcrease ohms to fit the oem amp. pioneer speaker = 2 ohms. pioneer amp = 2 ohms. double voicecoil speaker with 4+4 ohms wired parallel = 2 ohms = correct.
Old 02-08-11, 05:41 PM
Bali26
Bali26's Avatar
Can I somehow add 4 ohm resistance to the circuit so I can use the (almost new) 4 ohm nakamichi sub? Thanks
Old 02-09-11, 03:52 PM
p.hase
p.hase's Avatar
there is no way to compensate this by a resistor. of course you can but then you loose dB and the result is the same.
if you want to buy a good speaker from a 1947 founded italian professional audio manufacturer you could buy this one http://cgi.ebay.it/ws/eBayISAPI.dll?...m=370455535115 its cheap and its a honest speaker with all thiele-small parameters. i am sure they have a US distribution. note the pdf in this auction for data.
Old 02-09-11, 06:03 PM
Acidic
Acidic's Avatar
also you can't just "drop" a sub in... it needs to be mounted and sealed which isn't that easy... building a small MDF box for the trunk is MUCH easier... When I bought mine some guy had dropped a 4 ohm Boston acoustics sub into the hole and didn't even mount it to the deck let alone seal the mounting... what a joke. I run a 12" Image dynamics IDQ v2 now... it only takes 175w to make it romp...
Old 02-09-11, 06:50 PM
bornpeace
bornpeace's Avatar
I am actual correct, ur just skimming my post. When i say increase i mean buying an amp that will output 4ohms to go with the kicker http://www.crutchfield.com/p_113KAC5...ood+amplifiers a $69 solution plus amp kit from wal-mart for around $15. Use speaker-level inputs by taping the speaker wires under the passenger site were the OEM amp is or remove the clips from the sub wires and hook them to the speaker-level inputs(you may need to extend the cable depend on the location of the amp.
"p.hase" theory is also correct but good luck finding a 8" free air dual voice coil sub
Old 02-09-11, 06:57 PM
nine3es
nine3es's Avatar
i have both a nakamichi sub from a 90-94 LS its 5 ohm and a nakamichi sub from a 96 LS its 6 ohm, both are 8". for sale PM for info.
Old 02-09-11, 08:57 PM
soarer88
soarer88's Avatar
P.hase I have a 125w+4 4ohms amp I plan on using 4 my mid and high is this coo or can I run a bigger. 250w+4 4ohms..will this be better and make it sound more crip and clear....I do plan on keeping my sub but going wit JL audio w7.....any help would be great thanks
Old 02-10-11, 02:55 PM
p.hase
p.hase's Avatar
how can a car battery deliver 1600w? tell me! what you could do to play crisper and louder is cutting all midbass-speakers at 125hz by adding a single/simple/cheap electrolytic capacitor with a small high end bypass foil capacitor and thus generating a -6dB HP crossover. then install a good independent subwoofer to deliver ALL bass work up to 80hz from the back. you could always try to install a 10" woofer from the trunk side to a sealed wooden ring which is attached inside the trunk and sealed with silicone. it would blow through the 8" opening. this one would be great: http://www.igtek.it/subwoofer-ciare-...00w-p-491.html
Old 02-12-11, 05:16 PM
python
python's Avatar
here ya go
http://www.crutchfield.com/S-UPSLOPz...r-Comp-C8.html
Old 04-27-11, 12:03 PM
feetsies
feetsies's Avatar
Originally Posted by JAndersson
According to lexls.com (http://www.lexls.com/tutorials/audio/subwoofer.html) the Kicker Comp 03C84 should work. You can buy it here: http://www.amazon.com/dp/B0002DFK3C/...SIN=B0002DFK3C and it cost $53
Another option is DLSOA8 (http://www.dls.se/en/car/prod.html?produkt=en_120) but then you have to change out your original sub amplifier to one that have the power to drive the subwoofer.
The subwoofer should be made for open air, free air or infinite baffle (same thing just different names), and if you want to maintain your original sub amplifier it should have a impedance on 2 Ohm and have a RMS value around 50W. And finding a subwoofer like that is really hard.
Great post. I have the Nakamichi system in mine. If I wanted to upgrade to an aftermarket 8" sub I would just have to get a amp to go with it? Could I use any wattage amp or does it have to be specific wattage/ohm?
Old 04-27-11, 12:18 PM
Rey
Rey's Avatar
You would buy an amp to suit the specs of the sub you choose. Keep in mind when running a sub IB it is a lot more efficient compared to running it in a dedicated enclosure so less power is required.
Im considering running this in my LS as I want to keep trunk space. Ive already lost one corner to the tank and compressor for my air suspension. Plus im having a kid soon so ill really need the space. The specs of this driver will work well in an IB configuration.
http://www.parts-express.com/pe/show...number=293-657
Old 05-02-11, 01:51 PM
acidfire52
acidfire52's Avatar
I just replaced my stock sub in my '97 with this: Kicker 8" COMP
Put an appropriate amp on it and sounds great. Plenty of boom.
Old 05-02-11, 01:58 PM
Hilux22RE
Hilux22RE's Avatar
I Used a Pioneer TS SW841D Shallow Sub Following http://www.lexls.com/tutorials/audio/subwoofer.html And it Sounds Incredible!!
I Didn't think i could get that sound with a Stock Amp!!
Old 05-02-11, 02:01 PM
Hilux22RE
Hilux22RE's Avatar
Forgot To Add I Have a 1991 LS!
Quick Reply: Subwoofer Replacement Ideas?
