91 ls400 Cam Seals leaking. help.
Old 02-06-11, 06:15 PM
DuganFire
DuganFire's Avatar
Default 91 ls400 Cam Seals leaking. help.
I've recently had a horrible leak, that has been identified by a mechanic that its the cam seals. He gave me an estimate of roughly $400-$500. Is this average?
Also if I'm going to go through with the work, is there anything else that i might want to consider having replaced?
The car has roughly 130k. thanks for your time!
Old 02-06-11, 06:35 PM
deanshark
deanshark's Avatar
The cam seals are usually part of the timing belt job. If you're going in there ya might as well think about doing your timing belt/water pump job. Seeing how the cam seals are only about $10 each, 95% of that price your mechanic gave you is labor. You'd really kick yourself if you still use the old t-belt/water pump and it decides to go the next week. You'll just have to pay it all over again. If you do decide to do the T-belt then also do the crankshaft seal. Here's a tutorial on the T-belt. http://www.lexls.com/tutorials/engine/timingbelt.html It doesn't show the seals but they are only 10 more minutes work. Too bad you aren't closer, I would do it for less labor then that.
Old 02-06-11, 06:39 PM
DuganFire
DuganFire's Avatar
@DeanShark thanks for the quick reply!
Old 02-06-11, 07:42 PM
NjRican
NjRican's Avatar
good luck man.
Old 02-07-11, 06:29 AM
entryspeed
entryspeed's Avatar
My gs400 is in the same boat, taking it in today to get timing belt seals water pump etc done. My uncle is doing it for me @$500 including the parts kit to do all that. He said he normally charges $600-700 including the parts and does them in the better part of a full day. GL w/yours Im bummed.
Old 02-07-11, 06:52 AM
python
python's Avatar
a mechanic diagnosed my oil leak as cam seals but it turned out to be from the rear plug in the head on the drivers side which dripped down on a loom and traveled to the front of the engine. did ur mechanic have u put some dye in the oil? or did he take just look at the oil dripping?
Old 02-07-11, 08:45 AM
DuganFire
DuganFire's Avatar
spoke to him this morning, he visually diagnosed it when it was on the lift. I also asked him about 3 or 4 times just to verify lol.
good news, he's going to replace the cam and crank seals, timing belt +, and flush the tranny for under $700. Hopefully this will solve the majority of my problems.
Thanks to everyone who has replied. will update asap.
nice2mice
02-06-18 06:31 PM
ScottGS300
10-15-15 01:23 AM
paulv85
13
05-05-14 07:51 AM
PjLex
10-12-13 06:05 PM
rxpx40
06-05-11 02:31 PM
Quick Reply: 91 ls400 Cam Seals leaking. help.
