I bought a Wood Wheel now Need Instructions
Old 08-17-02, 08:47 PM
Horta
Horta's Avatar
Exclamation I bought a Wood Wheel now Need Instructions
Hey All
Well I just bought a wood Steering wheel from a 2000 LS400 on ebay.
Now I need you help and instructions on how to replace my steering wheel with out blowing the airbag or doing any other kind of damage.
Thank all and I really hope you can help.
Jerry
Old 08-19-02, 01:44 PM
Horta
Horta's Avatar
Hey all 15 views and only 1 reply can anybody out there help me?
Old 08-19-02, 09:22 PM
VVT-i
VVT-i's Avatar
You will need to disconnect the negative terminal from the battery. Make sure your steering wheel is straight. Then use the small flat head screw driver to pop out the sqaure covers on the bottom side of the steering wheel. You will need a torx bit #30 to remove the air bag. After you remove the air bag, you will need a 19 mm socket to loose the nut that hold the steering wheel. Then you will need to yank it really hard to get it to come out, but make sure you put the nut on the thread . So, when it come loose it won't hit you in the face. Hope this help.
Old 08-19-02, 10:49 PM
jahummer
jahummer's Avatar
That's what I did...
Old 08-20-02, 12:15 AM
Horta
Horta's Avatar
Excellent Thank you. I will give it a try when my new wheel comes in.
It sounds easy enough.........
Old 08-20-02, 06:05 PM
Horta
Horta's Avatar
Talking
I know have detailed instructions with pictures. Its from the Lexus Shop manual.
If anybody wants a copy I can fax them to you.
Jerry
ShawnOk
12-29-15 08:46 AM
CrispyST3
SC- 1st Gen (1992-2000)
01-30-12 04:20 PM
djsurfer
08-27-10 09:46 PM
mdt525
01-14-03 03:45 PM
JacobT
09-07-02 02:09 PM
Quick Reply: I bought a Wood Wheel now Need Instructions
