96 LS 400 idle going up and down
The way to test that ICV is to run positive jumpers to the two middle pins then ground the others. Mine was cleaner than that and it failed. Mine also ran just like yours. Just my recent experience. Rockauto.com had the part and it idles great now. If your MAF sensor is going bad I doubt it would run at all. I talked to a Lexus mechanic at the dealer and he said the ICV is a fairly common problem with this motor.
Do you know of a way to test the MAF and/or have PDFs from the FSM?
so i did everything that was updated cleaned MAF and started the car after 30 seconds there comes the wild idle and a lot of smoke from the engine. i don't know what to do any suggestion i want to take the car to a shop but car is not registered and would hate to get it taken registration is 510 so i would really like to have the car running good before i put that money into the registration......
ok so i turn the engine on and then turned off ran to the engine and i can hear something like a vacuum leak but cant find it for nothing is there some kind of diagram that shows all the vacuum lines???????
Spray carb cleaner on the tubes going to the engine, if you hear it rev you've found your leak. I would be careful spraying brake parts cleaner on your MAF filament. It's easy to damage it and brake cleaner is some hardcore stuff. Have you tested the ICV yet?
so the problem is finally fixed after going to the pick and pull and replacing the ICV.... thanks every one for your help.... saved me thousands of dollars
340massive
05-04-15 02:10 PM
