Coolant Sensor
Wow memory loss.
Did you forget you already asked this question yesterday? Search is your freind. This took a couple seconds to find. https://www.clublexus.com/forums/ls4...-in-1-fix.html It's located in Pure Drifter's 1995-2000 FAQ.
I hope you're asking about the "Coolant Temp Sensor" b/c there are 3 coolant sensors. (ECT, gauge, and fans)
Wow memory loss.
PureDrifter is a member here with a FAQ section for the 95-2000 LS's. I don't use it b/c mine is a 93 but I figured I would point it out to you. The link I gave you tells ya where it is located. Second paragraph, says it's under the throttle on the passenger side.
mjr955201
Performance & Maintenance
06-08-16 12:29 AM
DanielDD
12-04-14 03:55 PM
sbman1990
05-26-06 03:38 PM
