Tune up gone bad!! HELP REALLY NEEDED BAD!
I had a similar experiance not to long ago when I changed my spark plugs, only I had sprayed some throttle body cleaner into the throttle body and I had thought I had cleaned up everything. A few days later I was having problems with the car stuttering and wouldn't accelerate. I also got the misfire code. When I took everything off, I noticed that some residue had flowed out of the throttle body and had fallen over the spark plugs. When I removed the spark plugs, two of them had liquid. It was the cleaner. What I did was cleaned and dryed off the spark plugs and wires, then got a long extention and taped a paper towel sheet around one end (made a giant q-tip) and just cleaned up all the cyliders as far as I could go. After that I reinstalled everything, fired it up and its been running perfect. One last tip: don't forget to plug your maf senser when your done.
Thanks again man.
+1 on the MAF vs. AFM, but in reality, we all understand what your talking about.
Degreaser shouldn't really create any problems, only dilute the oil slightly, but your likely going to have oil flowing to wash the degreaser away. If you have any worries, changed the oil and filter.
I didn't read every single word, but try putting the old plugs and wires back in.
Thanks for all the info guys. I got it all figured out. I re-did everything and tested all the plugs and wires with a tester and sure enough two of the plug wires that i bought does not read any resistance at all it is open in other words. so i returned the plug wires and replaced it with a different one and my UNICORN is back! I thought i was gonna lose her for a minute there!
To get the degreaser out just crank the motor with the plugs out and remove the fuel injection fuse and anything inside the combusting chamber will eject. On the rough idling; check the gap and on some plugs theres a additional head piece to fit diffrent plug wire.
I found the problem guys! Its not the degreser that caused the rough idling, it was the distributor rotor. Replaced them both cause one of them was literally falling apart. After replacing them, my unicorn is back. You just really have to trouble shoot every part of the ignition. Hooe this will help everyone who will have similar problems.
1980, 1993, 92, 95, arcing, bad, coil, distribitor, lexus, ls400, ls400 tune up, mod, tune, tune up gone bad, tuneup
