intermitten chirping... how long does idler, bearings last?
this morning i heard chirping near the belt, sprayed some belt dressing it went away. later after car sat for a while, i started and chirping came back...
looked at the dealer service record and it had "REPLACED TIMING BELT, WATER PUMP, TENSIONERS, IDLE BEARINGS" around 30k miles ago.
does tensioner mean idler pulley?
There are both a tensioner and idler pulley(s) on the timing belt and the sepentine belt (alternator drive belt).
The sepentine belt idler can make this noise,mine is worse in cold weather for a few minutes until the engine warms up and has been like it for 4 years.
As Billy says check the condition of the belt and replace if worn.
If you look under the hood towards the front edge there should be a sticker on there showing the belt and routing.
![](http://i39.photobucket.com/albums/e191/stevestvs2006/fanbeltlabel.jpg)
The idler is easily removed so that you can give it a spin test and check for bearing runout. It isn't a big $$ part and if you have a press, you can press the old bearing out and replace. The idler is like a $45 part.
Mine was making a chirping too and the bearing was worn. In my instance this came somewhere around 120K.
thanks dudes. unfortunatey, chirping has now graduated to almost grinding noise... sprayed dressing near idler pulley, helped a lil, but seems to get worse... just gonna replace the idler pulley soon.
Check out http://www.planetsoarer.com/cambelt/cambelt.htm it has a good write up with pics for it. It's right down the bottom.
so changed the serpentine belt and chirping went away, car idles smooth. however, i noticed the white marks didn't line up at all. attached pic is not my car, but on my ride, the white mark on bottom pulley is WAY left to number 10. shouldn't this line up? if so where and how is this done?
i'm not a mechanic, so if lingo is weird or if this sounds amateurish, i ask for yr understanding and help a brother out.
appreciate it.
appreciate it.
hey deanshark,
i did check all pulleys and they spin freely/silently with no play so it was the belt.
white mark i'm referring to is single white mark/line that's facing or below the numbers 10 to 0. but this single white mark is nowhere near 10, but way left to it. does this make sense?
hey deanshark,
Also, in your first post, the tensioner that was changed with the T-belt job would be the T-belt tensioner, not the serpentine tensioner.
i sprayed hell load of belt dressing and maybe it made already brittle belt dry? perhaps that made it sound like it was grinding. i was looking into idler pulley and tensioner for s/belt just in case. and yes after some researching i finally figured out 2 separate system. s/belt and t/belt. thanks to all those who walked this path before i. did u ever get that afm @ j/yard?
that center cap is like the most difficult thing to find... if u see 1 up to 4, please grab 'em all. chrome with logo. started the car this morning, no chirping,,, happy thus far. and last pic attached was courtesy of maxx999.
Idler pulley is only a pulley. The tensioner keeps the tension on the belt. They are good for at least 100K miles and probably more. How many mile son the car?
