Air Conditioner compressor not engaging in 50 deg weather - normal?
Hi everyone,
I recently changed my timing belt along with water pump, seals, idlers, etc. Since I have a 2nd car, I was able to do this in my garage after work over a period of 2 or 3 weeks. Anyway, I was driving the car today and decided to try the a/c and noticed that the compressor wasn't kicking on. The outside temperature today must have been about 50 degrees. My 1st question is, is the compressor always supposed to kick on, or does it depend on whether the cabin temperature is below the climate control setting? Also, if it is supposed to be on, is it possibly related to anything I did while changing the timing belt, or is it just a coincidence. Btw, I also haven't seen my electric cooling fans turn on, even after driving for a while and I suspect I may have a problem there as well, though the water temperature is within the normal range. Thanks for any help.
Super Moderator
If the temp setting is for max cooling, the A/C compressor should cycle in. Probably a loose connection and or the clutch went bye-bye.
Another probable loose connection with the fans. I haven't ever heard mine cycle on even when in Vegas during summer. Makes me wonder now.
You might have pinched the wire to the A/C when you put the fan bracket back on. I think that is part of the harness that runs through the fan bracket. Also, changing the T-belt your supposed to unplug the A/C and the temp sensor on the radiator, (that one is for the fans) did you plug them back in? If you worked on it that long (short periods at a time) you might have over looked those plugs.
https://www.clublexus.com/forums/ls4...r-problem.html
Looks like I will follow the same steps you took. It's just kinda weird that this started right after I changed the timing belt. Could be a coincidence, but deanshark has some good advice as well. I don't think I pinched any wires or left any unplugged, but I will double check. I definitely know that I plugged the radiator temp sensor back in, that controls the fan based on water temperature. Maybe it just wasn't hot enough for the fans to kick on as the ambient is still pretty cool.
Oh - somnoboy, I assume when your compressor wasn't kicking on, the fans weren't going on as well, right?
Thanks to everyone for your responses
91ls
I've never noticed the operation of the radiator fan. I have no idea if it's on or off, or always on, or always off.
If you are referring to the cabin air fan: When I was having my a/c issue, the cabin air fan was working fine.
blkstealthpaid4
07-09-04 01:10 PM
