Subwoofer grille rattling!
Old 03-28-11, 03:27 PM
ravig292
ravig292's Avatar
Default Subwoofer grille rattling!
I have a 2000 ls400. The rear deck subwoofer is making the grille rattle. i know there is nothing wrong with the subwoofer because when i take the grille out it sounds fine. the only way to stop the rattling is if i put force on the middle of the grill.
Has anyone every fixed this problem while still having the grille on?
Old 03-29-11, 09:07 AM
StevieA
StevieA's Avatar
Mine rattles too - '93 with 1,000 watts & 2-12" subs in a ported box in the trunk. For now I just pulled the grill back and it's sitting on the rear dash so the tailight can still be seen & grill no longer rattles. But it's also not secured. When I have time I plan to try it back in place with some rubber or weatherstripping between window and grill & see how that works. I've heard from others it worked for them,
Old 03-29-11, 04:44 PM
Acidic
Acidic's Avatar
You need some dampening material... if you where local to me in NH I have some of the liquid stuff (can't really ship it) laying around... go here
http://www.secondskinaudio.com/vibra...lifier-pro.php
the $10 1sq ft should be all you need...
Old 01-09-15, 06:37 PM
mattylex77
mattylex77's Avatar
Default Fixed
I had this issue. Took the grill off the sub and poked around, couldn't find anything wrong with the sub. Then with the music on I wedged my fingers between the third brake light housing and the glass, sound gone. So I just wedged some rubber material between the housing and glass. Sounds perfect again...
Hype1147
07-23-16 10:26 AM
Halzlow
06-06-14 10:21 PM
sdpq
09-11-06 08:12 PM
akdmks
SC- 1st Gen (1992-2000)
15
01-27-06 02:35 AM
heyheyhey
12-14-05 08:03 PM
Quick Reply: Subwoofer grille rattling!
