Anybody tried '04-'06 LS430 5 spoke rims on an LS400?
Thinkin about puttin some '04-'06 LS430 5spoke rims on my LS400. Might give it a more modern fresh look. Anybody done this or have pics of it?
thx
thx
The one wheel that won't fit up without an adapter is the LS460's. Pretty much any Lexus wheel can be a contender so long as there is brake caliper clearance. That eliminates some IS, GS, ES..etc wheels unless a spacer is used. With the conservative offsets of these factory wheels, it shouldn't be a problem to use them. Depends if you like-don't like using spacers. (Speaking conservatively where fitting up a 25-30mm+ adapter to make an aggressive fitment.)
The wheel thread has plenty:
https://www.clublexus.com/forums/ls4...eel-setup.html
And the big picture thread:
https://www.clublexus.com/forums/ls4...of-ur-car.html
The one wheel that won't fit up without an adapter is the LS460's. Pretty much any Lexus wheel can be a contender so long as there is brake caliper clearance. That eliminates some IS, GS, ES..etc wheels unless a spacer is used. With the conservative offsets of these factory wheels, it shouldn't be a problem to use them. Depends if you like-don't like using spacers. (Speaking conservatively where fitting up a 25-30mm+ spacer to make an aggressive fitment.)
stock 2LS calipers require generally no more than 15mm spacers, so you can either use a spacer+extended stud (please don't pound them out with a hammer, you'll destroy the wheel bearings) or a bolt-on adapter.
many oem wheels will fit 2LS brakes w/o spacers, there are a few lists on the forum if you search.
JeffsLS400
03-15-12 01:38 PM
2BENVD
04-14-11 07:48 PM
