Transmission Filter, drain plug and Gasket question.
Old 04-05-11, 05:58 AM
DK Audio
DK Audio's Avatar
Default Transmission Filter, drain plug and Gasket question.
I’m getting a transmission filter kit from AutoHausaz. Which one would be better, the one by Mark Automotive or the one by CRP? The Mark Automotive one is more expensive; both come with a pan gasket so I would not need to use FIPG. I could also just get the filter by OES Genuine and use a FIPG.
Also is the oil drain plug gasket the same one that’s used on the transmission drain plug?
Thanks
Old 04-05-11, 02:02 PM
DK Audio
DK Audio's Avatar
I ordered more expensive Mark Automotive. The pan gasket appears to be better.
I also ordered 2 oil drain plug gaskets hoping one can be used for the transmission drain plug as well.
Old 04-05-11, 02:22 PM
bornpeace
bornpeace's Avatar
I dont think it matters but transmission use a soft copper gasket http://lexus.sewellparts.com/accesso...1999/2627.html
Old 04-06-11, 09:33 AM
DK Audio
DK Audio's Avatar
Hmm, interesting, can the tranmission one be re-used or should it be replaced? I am not leaking anything right now, just figured I would replace it since it is easy.
Old 04-06-11, 10:21 AM
91LS400vgb
91LS400vgb's Avatar
Default best to always replace the drain plug gasket on the transmission pan
I like to replace it every time as it lessens the chance of over-tightening the drain plug, which strips easily.
mekelly
12-07-20 11:16 AM
Hgspine
RX - 1st Gen (1999-2003)
05-14-18 05:36 PM
mansito
GX - 1st Gen (2003-2009)
08-31-14 06:31 AM
Sup2jzgte
SC- 1st Gen (1992-2000)
04-06-10 12:19 PM
Sweet95LS
03-07-09 12:45 PM
Quick Reply: Transmission Filter, drain plug and Gasket question.
