Just put in a new JDM motor. Only dash has power, no crank. Help?
Old 04-07-11, 10:10 AM
caliLS400
caliLS400's Avatar
Default Just put in a new JDM motor. Only dash has power, no crank. Help?
My LS had some serious cooling system problems, years of a lack of Toyota Red is my guess so I tossed that motor and put in a new JDM for $325, www.attarco.com. (FYI learned that JDM's are not such an easy swap for a California car. Many things need to be changed over from your original motor.)
To make a long story short, I replaced everything, went through all the checks and tried to start it. I knew that I had a problem when I hooked up the battery and had no dome light, when I turn the key, no fuel pump prime, no pdl or windows, no headlights, no radio, etc. Just my dash lights up and when I turn the key I get no crank. I checked all the fuses and the engine to frame ground wires, these all seem to be ok. I doubt it is the starter because of all of the other electronic stuff that is not there. Any help would be greatly appreciated. Thanks.
Old 04-07-11, 10:55 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
go check ECU grounds to the block.
then check fuses.
Old 04-07-11, 11:07 AM
acidfire52
acidfire52's Avatar
Good old engine ground. Had a car once I forgot to tighten it, started once, then no more. Spent 2 hours looking for the problem till I saw it. lol
Old 04-07-11, 02:01 PM
caliLS400
caliLS400's Avatar
Thanks for the replies I forgot to note I have a 92 LS. Which ground is this? Is is located under the glovebox where the actual ECU is or does it come off of the engine harness that goes through the firewall. if I remember this connects on the back of the engine and there is also another one on the driver side of the engine?
I would upload pics from my electronic manual but my PDF is corrupt all of a sudden for some reason.
Losaun
GS - 1st Gen (1993-1997)
16
02-26-10 06:28 PM
One_jZ_SC3
Performance & Maintenance
05-03-08 10:27 AM
GTE_SC3
07-10-07 02:31 PM
FL1PP3D
07-01-07 02:03 PM
Ducky
03-07-07 04:01 PM
Quick Reply: Just put in a new JDM motor. Only dash has power, no crank. Help?
