Car bucks
Old 04-22-11, 07:21 AM
paulwall86
paulwall86's Avatar
Default Car bucks
I have a 91 ls400, was sitting for a year got the tranny replaced and know when I try to do a 0-60 it starts to buck until i let off the gas. I put some fuel injector cleaner and the car stops bucking as bad. Do I need a tune up or a new fuel filter or fuel pump.
Old 04-22-11, 07:48 AM
Wanderson
Wanderson's Avatar
How much has it been driven since it was parked for a year? Could be bad gas, or a sticky fuel injector. If so, easiest fix is more cleaner & run a few tanks of fresh gas thru it. If it's sat with less than a full tank there's a possibility of rust/contamination which you should see by pulling the fuel filter, which would be a good time to replace it anyways. I think the fuel filter on your car is just forward of the rear axle on the driver's side so it's easy to get to, if you don't want to replace the filter I'd at least disconnect the fuel line from the tank to the filter and catch some gas in a clear jar and inspect it.
Old 04-22-11, 09:28 AM
paulwall86
paulwall86's Avatar
Thanks will do, I appreciate it. You don't think that it could be spark plugs?
Old 04-22-11, 11:22 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
check spark plugs/wires/rotors/caps/ignitors, and make sure trans has Toyota T-IV fluid, not dexron.
mbbf
Performance & Maintenance
02-04-13 04:36 PM
RedPhoenix
15
04-18-07 05:07 PM
LazyAlex
Maintenance
04-28-06 07:23 PM
Spitfire86
Maintenance
07-05-05 08:08 PM
fallabel
07-08-03 09:12 PM
Quick Reply: Car bucks
