93 ls400 dash problem
Old 05-04-11, 11:37 AM
flashy5
flashy5's Avatar
Default 93 ls400 dash problem
Ok I have a 1993 Lexus ls400 and I have a problem with the dash. When I first turn on the car the dash will flash on the cut off.The after driving for 5 or 10 minutes the dash light start flashing and eventually come one also the speedometer gets stuck at times then all of the sudden just work, can anybody tell me whats the problem could be
Old 05-04-11, 12:00 PM
Hilux22RE
Hilux22RE's Avatar
http://www.lexls.com/tutorials/lighting/bulbout.html
This might help with the lighting Issues.
Old 05-04-11, 12:12 PM
flashy5
flashy5's Avatar
i had that problem with the reverse light coming on and the car jerking a little that solved that problem but not the dash light coming on
Old 05-04-11, 12:13 PM
deanshark
deanshark's Avatar
That link is good and it clears up alot of electrical problems but I think his dash is a little more complicated then that. (I could be wrong)
Stickied on the top of this page (The first thread posted) is the https://www.clublexus.com/forums/ls4...fo-thread.html which has the answer to all your questions. In it you will find https://www.clublexus.com/forums/ls4...-not-work.html check out post #30, Och has a fix for the speedo needle. I'm thinking about doing it. His pics are gone though.
Old 05-04-11, 12:22 PM
flashy5
flashy5's Avatar
yeah that seems to solve the speedometer problem but not the dash light issue
Old 05-04-11, 12:36 PM
deanshark
deanshark's Avatar
In the same stickied newbie thread under "How to fix your speedo needle when it does not work", https://www.clublexus.com/forums/ls4...eedle-fix.html if you can solder.
bjjenkin
04-05-18 12:36 PM
Eagleguy
ES - 6th Gen (2013-2018)
11-24-13 05:06 AM
ISRabbit
05-17-12 08:30 PM
CeoStatus0
12-25-06 06:18 PM
mcummins
Maintenance
09-28-05 07:42 PM
Quick Reply: 93 ls400 dash problem
