1991 1jz ls400 swap
well i have had the car for about a year now and has ran great it has 205000 miles and is starting to smoke so i decided time to change the engine i had a 1jz sitting in the garage from my old truck i had so i thought why not did lots of research and after doing lots of convincing the wife i started the project it has taken about two monthes to do i am almost done i am waiting on my 1pc driveshaft from driftmotion and then i can drive it to the shop for exhaust and intercooler pipe then its done
Engine:
1jzgte from chaser
single hx35 turbo
ebay manifold
xs power 46mm wastegate
stock injectors for now
driftmotion underdrive pulley set
Transmission:
a341 from chaser swap
usdm 2jzgte torque converter
usdm 2jzgte bellhousing
Electrical:
conversion wiring harness i did myself
Safc2
straight wired fuel pump
255 lph tre performance fuel pump
winter tire setup will be getting new wheel and lowering it
the intercooler painted black (sleeper)
![Name: DSCN3510.jpg
Size: 183.5 KB](https://www.clublexus.com/forums/attachments/ls-1st-and-2nd-gen-1990-2000/434369d1501365208-1991-1jz-ls400-swap-dscn3510.jpg)
Engine:
1jzgte from chaser
single hx35 turbo
ebay manifold
Transmission:
Electrical:
Safc2
![Name: DSCN3447.jpg
Size: 82.1 KB](https://www.clublexus.com/forums/attachments/ls-1st-and-2nd-gen-1990-2000/434368d1501365208-1991-1jz-ls400-swap-dscn3447.jpg)
![](http://i637.photobucket.com/albums/uu96/kaylaseprish/DSCN3451.jpg)
![Name: DSCN3511.jpg
Size: 188.0 KB](https://www.clublexus.com/forums/attachments/ls-1st-and-2nd-gen-1990-2000/434370d1501365208-1991-1jz-ls400-swap-dscn3511.jpg)
what pure drifter said i didnt have to do any modification to the car at all the transmission bolted up to the stock location then i used the chaser mounts that came withthe 1jz and the stock rubbers the passenger side lined up great i had to make a little extension about 2 inchs on driverside it save me some money instead of trying to find the aristo mounts ill get more pictures of the swap and i have a video on youtube of the first startup it kinda sucks but it shows it running look for 1jz ls400
well i took it for the first test drive today it runs like crap i doesnt shift out of first gear and it acts like it is hitting like a launch control when free reving and when i drive it and give it more than 20% throttle it acts the same way the turbo starts spooling but it feels like it is just stalling any ideas?
