Finally Got My Fenders Fixed
Old 05-29-11, 11:17 PM
bboynoodle
bboynoodle's Avatar
oh nice, thanks. Yeah i've been trying to find a used passenger '99 fender. Don't feel like spending 350ish on a new one for lexus =/ Glad you got your car all fixed for now. Looking ill!
Old 05-30-11, 09:05 PM
AuckB
AuckB's Avatar
ooowiee thats clean!
Old 05-30-11, 09:14 PM
Lazy
Lazy's Avatar
What's ur wheel specs anyways?
Old 05-30-11, 10:02 PM
jasonm
jasonm's Avatar
fronts: 19x9, +12 but needed a 10mm spacer to clear brakes. Tires are 225/35/19 Nitto Nt555
Rears: 19x10, +9, 235/35/19 Nexen
Old 05-31-11, 07:31 PM
Lazy
Lazy's Avatar
so ur running 19x9 +2 up front? I was going to use my buddies 19x9 0 up front but my 19x9 +10 already rubs a bit.. What suspension mods/ body work did u need to do? Camber kit? Pull/roll? Don't need help with the rear since it's the same as ur set up I want to try to fit 10.5 +10R but it would need a flare or more camber..
Old 05-31-11, 08:31 PM
jasonm
jasonm's Avatar
For the fronts your gonna need to roll flat that inner metal and slight flare/pull. The rear; cut and find some way to pull a little. I cut mine and used a 80 grit flap disc from The Home depot to grind it flat on the inside and still needed to pull it...I actually used a metal bar and was very caring with it but wouldnt recomend it...a roller should work but be easy so that you dont split the the metal from the body from the inner metal.
Old 06-01-11, 12:35 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
your 1LS will have very different fitment, the 2LS had a LOT more room front and rear.
enrgy
GS - 1st Gen (1993-1997)
12-14-15 06:13 PM
Stainless9
08-01-13 01:18 PM
MyIS350G
07-09-13 08:45 PM
dee714
09-25-09 06:20 AM
tuninghaus
SC- 1st Gen (1992-2000)
03-10-07 06:39 PM
Quick Reply: Finally Got My Fenders Fixed
