Sounds like a machine gun when i start my car
#32
If the rest of the car is in good condition, applying these fixes may be practical but up to a point. If it is lots of wallet hurt, no sense in doing that unless you love the car for a project. 20 year old car, it will have plenty of worn stuff at the higher miles.
I do agree that looking for a newer one might be a better approach. Again, you can still have similar problems as now so avoiding them means going even newer as the odds decrease.
#34
Whoa horsey! Your battery wire should not be smoking under any circumstances, much less with the car in a mode where there shouldn't be a significant current drain. Find and fix the current drain first, then go back to the starter and battery.
#35
Well, if you already have the intake manifold off, and you're at the starter, why not just rebuild the starter seeing how the hard part is already done? Try hunting down the elecrical problem, it shouldn't be too hard. I was reading some of your old threads about your electrical problems, 2 years ago, and it seems like your problems started with wiring up your fogs with no relay. Did you ever fix that up? That's where I would look if you have an electrical drain.
Quick question; If you have the intake off how did you try to start it? Wouldn't everything electrical be unplugged already? I never took my manifold off so I'm not sure about it.
#36
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
so pretty much my only option is to part out this car & get it towed away & get another car. a higher year LS maybe or something else on the VIP platforms.
with the intake mani off, i just tried to see if the starter would turn over but it was frozen. no budge what so ever
djrazr
Performance & Maintenance
04-19-12 10:45 PM
sherlock
21
01-14-10 09:45 AM
FireCode
02-06-05 12:15 PM
