Oil Filter
Old 06-11-11, 04:56 PM
RA40
Super Moderator
RA40's Avatar
The 90915-20004 is a nice filter. I've had oil analysis done at 6, 8, 10 and 12K miles. For ours, it has good filtering properties that I don't think of another. YMMV.
Old 06-11-11, 11:50 PM
j three
j three's Avatar
Wow, are you saying you have gone 12k miles between changes RA40?
Old 06-12-11, 12:40 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
i run german castrol 0w40 (iirc) and run 8-10k between changes.
Old 06-12-11, 07:04 AM
sleepywgn
sleepywgn's Avatar
I should be doing my oil change pretty soon, has anyone use the fram high milage oil filter and use eneos oil? I use to run eneos in my subie and it did the job, just wanted to see if anyone else ran it in there ucf.
Old 06-12-11, 07:57 PM
RA40
Super Moderator
RA40's Avatar
Yup. The additive package is dropping in the Mobil 1 by then though it still is sufficient to do as necessary if one stretches it. 8-10K is nominal in ours and the filter is still keeping up. I don't cut the filters open. The analysis is sufficient to determine that excessive wear particles in the oil that are not getting caught/filtered. Within normal spec, which is the goal.
Sorry, no analysis data to post, long deleted and the one hard copy, I'm not about to type up and that was wayyy back in '02 or so when I did the baseline at 60K. I wanted to determine what is a good drain-filter replacement schedule in ours.
The JDM 90915-20004 is quite capable. I recall seeing data from the Supra forum that expressed similar and there may be past discussion in the GS section as well. Suffice, this is a well liked filter but a bit $ now.
Old 06-12-11, 08:50 PM
sdls
sdls's Avatar
it won't matter - just use the STP filter. the car won't know the difference.
Old 06-13-11, 12:29 AM
j three
j three's Avatar
Yeah, I like these filters a lot. I have been using them since early 09. I got a great deal from another member two months ago, $60 shipped for 6 filters.
Old 06-13-11, 06:50 AM
sethjon
sethjon's Avatar
I use Fram in all my cars including the antiques. Also in the boat and never had a problem.
Old 06-16-11, 11:57 AM
somnoboy
somnoboy's Avatar
Default WIX 51348 v. NAPA Gold FIL 1348
Folks, are these two filters the exact same filter? They look IDENTICAL. In other words, does WIX make this filter for NAPA? If so, if I can get the WIX filter for $2 cheaper than the NAPA filter, wouldn't it make sense to buy the WIX filter? Especially if it is literally the same filter?
Old 06-16-11, 01:16 PM
PureDrifter
BahHumBug
you can call wix, they tend to reuse external casings so unless you cut two of them open you wouldnt be able to tell if the bypass and filter material is the same.
Old 06-16-11, 02:04 PM
deanshark
deanshark's Avatar
I read something recently, within a week, that Wix and Napa oil filters are made by the same company. I can't remember what the company is though. I was searching for something else and that came up.
Old 06-16-11, 03:25 PM
somnoboy
somnoboy's Avatar
Ok, thanks guys.
Old 06-16-11, 03:53 PM
PureDrifter
BahHumBug
Wix is the company that makes napa gold filters. wix also does a lot of OEM filters.
but you can't compare casings to casings, you either need to call wix to compare 2 model numbers or cut them open.
Old 06-20-11, 03:24 PM
sethjon
sethjon's Avatar
Originally Posted by python
any way u look at it...if u change ur oil on a 3,000 mile interval then its really not that important..when u let it go well past that then the better filters come into play
Well said!!
Old 12-20-12, 08:40 AM
iamkhanz
iamkhanz's Avatar
http://mkiv.com/techarticles/parts/t...ter/index.html
http://mkiv.com/techarticles/parts/t...il1/index.html
I second RA 40
Quick Reply: Oil Filter
