climate control
Old 09-11-02, 06:59 PM
rybikowsky
rybikowsky's Avatar
Default climate control
92 ls 400.Air cond has been working great,until yesterday,Air not very cold.And the front two fans are not running.Looks like plenty of freon and the compressior is working.I have the shop books but I dont understand what they are trying to tell me.HELP.Rybikowsky.
Old 09-11-02, 07:40 PM
wwest
wwest's Avatar
Default A/C
The most common problem is the drive cable having come off the hot water metering valve. The "blend door" servomotor is inside teh system under the dash but along with operating the blend door it has a cable which extends through the firewall and actuates teh water valve.
The water valve is mounted on the firewall near the top center at the rear of the engine with a water hose going in and another out.
If you move the temperature setpoint between 65F (max cold) and 85F (max heat) the cable should move the water valve from closed to open and vice versa.
Old 09-12-02, 12:37 PM
rybikowsky
rybikowsky's Avatar
Thanks for the reply.I will check that.Anyone have some advice on why the two fans on front of the radiator will not work.
Old 09-12-02, 02:06 PM
wwest
wwest's Avatar
Default fans
If I remember this right only one fan runs if the engine coolant is "threatening" to overheat and the second one will come on in that case only if the A/C is running. Otherwise check the fuses
Old 09-13-02, 07:33 PM
rybikowsky
rybikowsky's Avatar
Wwest.I checked the heater valve.It was working alright.Can the fans not working and the Ac suddenly not very cold be related to each other.Now a Strange thing.While I was checking the relays and fuses under the dash on the drivers side,I happened to push up on the plastic cover to get a better look.When I did that the fans started to run,just for a second.I could not get it to repeat.It is forty miles to my lexus dealer through some of the worst traffic in the country.I shur would like to fix it with some help.Thanks Michael Rybikowsky
Old 09-13-02, 09:46 PM
wwest
wwest's Avatar
Default again
If the front outside radiator cooling fans do not work and the engine water jacket is therefore slightly overheating then the A/C system will be disabled. But didn't you tell me that teh A/C compressor ran?
With the symtoms you relate you may have a fuse or a connection not tight enough, I would remove and replace all of the fuses (same fuse) just to be sure there are well seated.
Old 09-14-02, 12:37 PM
rybikowsky
rybikowsky's Avatar
Thanks West I will give that a try.When I get it fixed I will report back to the site to share The fix.
Aldiggy
06-14-17 08:30 PM
sc3dreamz
Performance & Maintenance
01-24-08 02:02 PM
BradE
12-16-05 09:46 PM
BriMcc
SC- 1st Gen (1992-2000)
01-08-02 02:26 PM
Quick Reply: climate control
