Help with fender rolling/cutting
Need to roll the fenders, F and R on my 93' ls400. I know the fronts usually dimple when rolling because of the tabs inside. I do not want dimpled fenders, so I'm thinking about shaving and rolling. If I go slow and take my time with a heat gun and just use the Eastwood will the fronts still dimple? Trying to fit 19x9.5 +22 F (225/35/19) and 19x10 +22 R (235/35/19). Btw I'm on BC coils.
*****UPDATE
![Help with fender rolling/cutting-1.jpg](https://www.clublexus.com/forums/attachments/ls-1st-and-2nd-gen-1990-2000/214257d1461115682t-help-with-fender-rolling-cutting-1.jpg)
![Help with fender rolling/cutting-2.jpg](https://www.clublexus.com/forums/attachments/ls-1st-and-2nd-gen-1990-2000/214258d1461115682t-help-with-fender-rolling-cutting-2.jpg)
my fronts came out pretty good , a dimple on each side at the tab hole towards the front of the fender arch and one towards the rear. and the rears themselves came out with very minor dimpling.
*****UPDATE
for the fronts, cut off the metal tabs, clean inbetween fender lip to get rid of all the dirt / rocks in there. Depending on how flat you want to roll will determine if there will be dimples or not. My fenders are rolled completely flat and i have minor dimpling. Take your time
so far I've cut the tabs where the fenders liners go. and trimmed the inner fender to about 1cm all the way across, I'm going to use a roller and go slow with heat. Vincent I've seen your car on WF, it's sick haha.
thanks for the info, do you mean you used the wheel to roll the fender by placing a a jack under it and pushing it up into the fender well?
Low Life
11-18-12 09:09 PM
SorrGwa
09-26-09 01:22 PM
