Alignment help
Old 06-16-11 | 08:53 AM
python's Avatar
python
Default Alignment help
ok so ive had my 92 on megans for over 3 years now and i have 26,000 miles on my fuzion ZRi 235-40-18 tires. i noticed the other day that my inner part of the tread on every tire is worn more than the outer part,so looking at the tire u dont notice it but bending down and looking its noticeable. so i took it to the alignment shop and they said i have negative camber and i dont have any more adjustment left...is this something i am going to have to live with? or,can something be drilled to make more adjustment or should i raise my car up 1/8-3/16 of an inch to help this...or should i just leave it and be happy with getting 25-30,000 miles out of a set of tires over a 3 and a half year period
btw my next tire im considering is this
http://www.tirerack.com/tires/tires....omCompare1=yes
thanks in advance for any informative replies
Old 06-16-11 | 10:10 AM
Rey's Avatar
Rey
As long as your toe is in check then youll just have to live with it. Id say 26k is plenty of mileage for z rated summer tires. If it bothers you that much you can just flip them.
Old 06-16-11 | 01:55 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500000
yep TOE is the biggest factor in camber wear. and yea just flip them.
Old 06-16-11 | 02:22 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
toe sounds to be in good shape, just flip the tires 2/3rds the way through their wear cycle on one edge and wear the other edge.
Old 06-16-11 | 03:27 PM
RA40's Avatar
RA40
Super Moderator
They have ya covered.
What was the neg camber readings? When it goes past -2, some tires just get eaten.
I've got 37K miles so far on the Yokohama S drives. Flipped them about 6K ago and I say these will get 45-48K miles. Of course my camber is wayy mild to many of you here. -1.5 front and -1.25 rear. (Rounded off)
Old 06-16-11 | 04:50 PM
PureDrifter
BahHumBug
CL Folding 100000
yeah i get WAY less than that...
0'd out toe, -1.8* front and -3.8* rear camber. get ~18-25k from Nitto NT555s (20")
Old 06-17-11 | 05:39 AM
python's Avatar
python
thanks guys....u answered my question...i can get another few thousand out of em. ill just live with it
Old 06-17-11 | 06:53 PM
python's Avatar
python
here are the specs
camber front:
left:-1.40
right:-1.05
camber rear:
left:-2.08
right:-1.72
Old 06-17-11 | 07:49 PM
PureDrifter
BahHumBug
CL Folding 100000
the car will drive a lot better if you even the camber out across the axle.
Old 06-18-11 | 06:46 AM
python's Avatar
python
even if its more towards the negative side? wont that wear the tires even more?
Old 06-18-11 | 01:22 PM
fatcat2's Avatar
fatcat2
if you flipped them like they were saying you should be fine for many more miles, even if they were more toward the neg side. all it would do is move where the wear will show up. say its at -2.5 instead of -1.5 it will get closer and closer to the inner side walls the more neg you are.
Old 06-18-11 | 04:15 PM
PureDrifter
BahHumBug
CL Folding 100000
the less than 1/2 degree difference wont make a huge impact as long as your toe is managed plus then the tires will wear more evenly across the axle and the car will be more predictable when turning.
Old 06-19-11 | 05:47 AM
python's Avatar
python
ok..thx for all the info guys much appreciated
Old 06-19-11 | 06:12 AM
Schnitz's Avatar
Schnitz
Uneven camber can make the car pull which puts added stress on the tires. I have -4 degrees out back and I'll get about 12k miles out of them.
Addiction
GX - 1st Gen (2003-2009)
02-20-18 01:29 PM
BradTank
IS - 1st Gen (2001-2005)
06-08-15 07:13 PM
Pivo154
12-07-11 10:24 PM
Lexy602
14
08-07-10 08:10 AM
