91 to 95 caliper
Guys need some help. Im in a process of putting a 95 LS calipers to my 91. but, I just found out that I need to change the lower ball joint? I have a SSKit is this going to solve my problem?
note the SSKit is not instaled.
thanks
thanks
You wil need to change the lower ball joint, Caliper as well as the rotor,as the 95 brakes and rotors are larger than the 91.The SS kit is only a small enhancement for the brake lines themselves.
by SS Kit you mean an RCA of some type right? NOT SS Brake lines?
if so, then you MAY be able to get away without using the later 2LS lower ball joints since you could have the right clearance, it really will depend on the thickness of the RCA you have.
otherwise, yes you need to swap out to the later 95-00 front lower ball joints.
also, you will need shims, pads, rotors, calipers, and caliper mounting bolts from a 95-00 LS to complete your swap.
thanks guys, im going to run a youzeland 20mm SSkit. and i forgot to buy the caliper bolt. ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
should i get a 95 brake shields? or just remove the old 91 brake shields?
thanks again
thanks again
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Finally finished my front brakes upgarde, total cost $600. This is a remanufacture front caliper brakes with new brake hardware, rotors & pads.![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
I just learned that the old caliper bolts from the 90-94 will fit the the 95+ caliper. but you need to trim or add a washer. because the top bolt will hit the back rotors. One thing more that the rotors need some shims. Remember that the rotors have "screws" to align. Hope you save it! cuz you need to install that back. That will be your guide to make a shims for the rotors or just live it as is, just like mine.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
This has been a great low budget 4 piston brake upgrade![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
pixs will be posted as soon as I get a camera.
Ok im about to Start rounding up the Parts to do this to my 1991. I am looking for Lower Ball Joints but i cannot find them new.. not only that but every Pick N Pull i go to there are no 95+ LS's there. I Dont want to go to the Stealership for these parts and i am trying to stay away from Ebay parts from what i have heard. Anyone know of a Place where i can get these parts?? I would Greatly Appreciate the help.
So far i have Purchased:
Calipers
Pads
Rotors
And Brake Lines.
Anything else i should invest into??
Calipers
Pads
Rotors
And Brake Lines.
Calipers
Pads
Rotors
And Brake Lines.
Calipers
Pads
Rotors
And Brake Lines.
where at in Ca are you located? today i went to pick n pull and there was a 95 with most of the parts still on it
Calipers
Pads
Rotors
And Brake Lines.
Calipers
Pads
Rotors
And Brake Lines.
you do realize that your solara wheels won't clear the 2LS calipers right?
I am Aware of that.. I Love my Solara Rims and dont want to get rid of them but i gotta do it! This is what i am Going to get my hands on from a dude that totaled his Camry a few days ago.
![](http://i1186.photobucket.com/albums/z369/Hilux400/TRDBaby.jpg)
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Do you have Any Recommendations on wheels for this set up?? i dont want to blindly throw money away.. i am getting a huge amount of doubt in my wheel decisions now...
it's been covered but any 95-06 LS wheels will clear, 06+ ISx50/GS350 wheels, supra turbo wheels, and any aftermarket wheel made for big brake kits will usually clear. those TRD wheels you listed MAY clear, but you would need to check as normal camry/anything else wheels won't.
