What's Wrong With This VIN?
Old 06-22-11, 09:12 PM
LS430black
LS430black's Avatar
Default What's Wrong With This VIN?
Here is the VIN of my friend's LS400:
And here is the check from CARFAX:
So it can be sure that the car was manufactured in '96, but at the upper right corner of the first pic shows 6/98. I don't really understand. Someone helps me, pls.
Old 06-22-11, 09:31 PM
JimsGX
JimsGX's Avatar
Along with the date discrepancy, the sticker says made in USA. All LS's are / were made in Japan...
Old 06-22-11, 09:34 PM
LS430black
LS430black's Avatar
But the 1st digit is "J", which means Japan was the manufacturer.
Old 06-22-11, 09:46 PM
JimsGX
JimsGX's Avatar
I just did a search for the model number on the sticker and it says that sticker is from a Toyota Camry built between 8-1996 and 7-2001...
Do a google search for: " Model: SXV20L-AEPNKA " and you'll see what I mean...
Old 06-22-11, 09:59 PM
LS430black
LS430black's Avatar
Whoa! That was tricky- a Camry VIN on a LS400. But I don't know why the whole VIN was of LS400, they couldn't have glued up the 2 different-VIN peaces into 1 perfect piece.
Old 06-22-11, 10:24 PM
RA40
Super Moderator
RA40's Avatar
Interesting, what is the VIN in the dash? How are the body panel stickers labeled?
Old 06-22-11, 11:24 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
possible solution:
car was in an accident/repainted and they didnt have lexus VIN stickers (this being vietnam)?
Old 06-22-11, 11:59 PM
LS430black
LS430black's Avatar
@RA40: The owner is checking it, I'm his friend. The label above was from the B pillar.
@PureDrifter: The case is in VN. If it were from another car VIN, the 17-digit line would also be from another car, not "Lexus" as listed by CARFAX. What is really confusing here is the mixed-up VIN info, I cannot figure out how they put all the "new" numbers (6/98, SXV20L-AEPNKA...) in the label and make them really clean, like it was original.
Old 06-23-11, 12:47 AM
PureDrifter
BahHumBug
SVX is a 4cyl camry chassis code, and the date and all appear correct, but the vin is the oddity here...
i would check the other vins on the body of the car to confirm that is the real vin.
Old 06-23-11, 03:27 AM
robert1408
robert1408's Avatar
10th character of the vin is T, indicating a 1996 year model. That doesn't jive with the 06/98 mfg. date. The 4055 figure for the GVWR is 400-500 low for a 2 gen LS 400. The U140 transmission shown is not correct.
Old 06-23-11, 05:36 AM
LiCelsior
Retired
LiCelsior's Avatar
dont see the UF21 code.
Old 06-23-11, 05:58 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,285 Likes on 1,391 Posts
Sounds pretty shady, definitely compare other VINs on the car
Look at the bright side, maybe he can get cheaper auto insurance
Old 06-24-11, 07:58 PM
trukn1
NELOC Mod
trukn1's Avatar
Check the vin on the dash to see if the 2 match up. Am guessing that they don't.
Old 06-24-11, 10:17 PM
fatcat2
fatcat2's Avatar
i wouldnt just check the dash, i would check all the vins possible. this is sounding very odd and sketchy.
Old 06-25-11, 10:44 AM
deanshark
deanshark's Avatar
There's deffinately something very fishy with this LS. Watch out b/c there are alot of shady characters out there. (chop shops) These stickers can be made up with some sort of label maker. There's also places that make replacement labels with just a picture. Like this: http://www.autodatalabels.com/place-an-order.html So if you can tape a couple together good enough to get a decent picture, you're all set. But like everyone is saying, "check all the other VIN numbers" Check dash, frame, engine, everything.
Quick Reply: What's Wrong With This VIN?
