95+ speedometer removal write up?
Old 06-30-11, 07:46 PM
SRV1
SRV1's Avatar
Question 95+ speedometer removal write up?
On my 96 the speedometer stopped working. I already searched and I found my answers but I did not see a write-up (tutorial) on the 95+ cars, I did find it for the 94 and older cars though! I have all the tools to remove it even the plastic trim removal tools so I do not gouge up the dash. If no one can link me to a write up then other than extending and lowering the steering wheel, is the rest self explanatory? Is there anything I should be aware of when pulling the instrument cluster out? If no one has done one, I will do a write-up.
James
Old 07-02-11, 08:23 AM
steve2006
steve2006's Avatar
I haven't seen a tutorial for the 95+ model but it can't be too dissimilar to the 94 year,just be careful removing the connectors as there is not a lot of free loom and don't forget to push the tab in to release the connectors.
If you could do a picture tutorial it would be greatly appreciated.
Old 07-02-11, 08:42 AM
Rey
Rey's Avatar
If you hit the dash does it start working? Theres a write up somewhere that covers cleaning it so it doesnt get stuck at 0.
Old 07-04-11, 11:34 PM
SRV1
SRV1's Avatar
I do not believe in hitting the dash. Cathodes in the dash can be fragile. Went out to the car the next day and it works fine now. Go figure.
James
Old 07-05-11, 12:22 AM
Rey
Rey's Avatar
You're not beating it, the speedo just needs a little jolt to get unstuck. I do it all the time so I don't think you'll have a problem doing it once to test if that is the issue. That's the easiest way to diagnose that issue unless you like wasting time and effort. It will work intermittently depending on ambient temp/humidity because of the chemical characteristics of the residue on the needle/stopper.
Old 07-05-11, 01:29 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
James
the cathodes are NOT that fragile. my cluster still worked after a head on collision that totalled my old LS.
Old 07-05-11, 04:38 PM
robert1408
robert1408's Avatar
Never had any problems with the cluster in my '97 till Sunday morning. I noticed the needles lighting up, then going off in a second or two. No dials lit at all. I must have turned the dash lights off when I cleaned the interior the day before. Turned the lights up, all was well. The feeling of relief was sweet!
kdick91
10-29-15 09:02 AM
Mtdave2
06-28-15 03:33 PM
Bdub215
SC- 1st Gen (1992-2000)
06-25-14 05:49 PM
dr gtr
03-15-08 12:51 PM
Quick Reply: 95+ speedometer removal write up?
