Who wants more POWER?
#47
go to www.swiftracing.com
I would strongly recommend their air intake/ecu mod. Don't waste your money on anyone elses as SRTs is WAY better (5hp vs 25hp). If you can get the torque converter also. Don't go cheap. You will be unhappy if you do. SRT may seem expensive but for the 2 grand the 2 items above will cost you you will be Lexus smooth, quiet and FAST. IF after these two items you want more...they will have a silent supercharger out in a couple months.
#49
I haven't tested it myself but from all the evidence I would have to say YES. First, it uses a MAF to TB tube that is slightly larger than the TB. This slows the air increasing its pressure at the TB (slightly larger is the key, much larger will loose more than it gains) effectively making the TB flow MORE
. Next, it uses a high flow filter and isolates it from the hot underhood air and feeds it cool air. Finally, it adjusts the fuel ratio lending maximum benefit. This is definitely the most power from an air intake mod that I have seen.
#51
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Check out this install....
http://www.mkiv.com/techarticles/ape...ter/index.html
http://www.mkiv.com/techarticles/k&n...ion/index.html
Great site...... www.mkiv.com
It has a lot of info that can be used in the LS forum, and thru-out the Lexus forum.... Browse thru the tech articles and the BPU "basic perf. upgrades" the have info about every thing and a lot of installation pics.....
Guys, I hope this info helps some one!!!
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#52
Guest
Posts: n/a
I have looking into the products offered by swift raceing and RMM, and while both have an impressive array of products for the GS400 (98-00) they don't really have a whole lot for the LS400 (98-00).
For instance I really like SRT's HFI kit. It seems well designed, and simply put, clean. I would probably purchase that as my first modification, as it looks like I could do the install myself.
BUT I am not sure that kit would work in an LS400. I do not know if there is a difference in the dimensions under hood between the GS and the LS.
Before I ask SRT I thought I would post this up and see if anyone else knows if this kit works in the LS400 or not.
Thanks for any replies!
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#53
I have talked to Mo at SRT and he told me they don't have a HFI for the LS4 as of right now but are in the process of working on one. He told me they are nearly done, just working out some kinks on the ECU. Can't wait to see this bad boy get installed on my car!
#55
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Bracket, you my friend will be in luck. I would also say to go with the TC.
#56
jbrady
Please keep us informed about your intake design....I, for one, am interested as I might think edogg is ...one of his later posts gave me the impression he wasn't completely satisfied with his set-up...from reading the information you have posted previously I would trust that what you design would maximize the intake without touching the ECU.
#58
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
Hey if you guys are looking for parts let me know. First if you want and intake for LS400, it easy and cheap. Rod Millen makes one but he wants 180+, you can get one for 55 bucks like me. Order a Supra adapter for about 25 or 30 bucks then a cone shape filter, make sure it is a cubber bottom.. Metal or chrom bottom would ba pain in the *** to get on the adapter. Secon for the Strut Tower bar. No one makes one.but... Order a new generation Supra modle bar, all you have to do is buy washer to prop up the bar. Stock the bar is not bent high enough to clear the engine so it vibrates it. So i put about 4 washer on each bolt, and it solves the problems. The exhaust. The best and cheapest was is to build your own cat back, if you have a kit or plan on getting one then this is great. First buy two exhaust any kind universal. then take it to a local exhaust, make sure they do quality work (what you pay is what you get). it shouldn't be more than 150-200 for the piping done. Tell them to cut all the old piping form the old cat-back. Just intsall a 2 1/2 pipe back, stright no bends, do not foll the old exhaust bend. Just straight and close to the body as possible, make sure it clears and make sure they sucure the pipe with lots of hangers. This stright cat-back should add about 10 hp, but i got to warn you it's kidda loud. So if you dont' like it that loud, but an univers exhuast with a silencer/baffle on it. For other mods e-mail me. IF you want these parts, email me too, i know a guys with a shop that is a lexus owner also so he give me great prices. Nguyennhu23@aol.com
Next...
I recently spoke with VIS, they said they can get me an evoulution kit. the kit comes with front bumber, sides (with door caps, about 6pcs total), rear, Eyes brows, and front grill, maybe a spoiler i'm not sure but i'll check. Anyways they said that they can ship the kit here from japan for me for about 950. I asked them what about a group buy, they said that i can probably get the kit for a couple of hundered cheaper then what they told me if i bought it by myself. So here we go.. E-mail me if you want to join the group buy it is Nguyennhu23@aol.com
you can view the kit at www.importfans.com
Go to their old site, the icon is near the middle of the page. Then products and then lexus LS400 kit. the kit that looks like the evolution is the what they call junction kit.
Hope to hear from you sooN!!!!
Next...
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#59
<center>Img src="http://members.asianavenue.com/ViEtLuvEr69/Untitled-1.gif"
here is a picture of me and my car. YOu can see the clear bumber light i got adn somewhat the strut tower bar, you can see the red bottom and part of the bar. So email me for parts and prices..
#60
Your pic doesn't work.
It is good to hear there is another mod junky on the LS forum then besides me, jbrady, edogg, and zushwa. On the exhaust note I thought About going universal but really didn't like the idea because it be more for looks then my plan to increase HP. Borla reintroduce their catback exhaust for it about a month ago for about $550 and HKS is almost done with theirs, in the process of dynoing it. Of course the HKS will be very expensive but I like to do things right so I can wait, also gives me time to save for it.
The air intake sounds very good idea except the problem me a jbrady have is prventing heat from the engine. I am in the process of creating a heat sheild and will post pics as soon as I'm done with comments on any improvements or not.
The strut bar, there is one available but it is a JDM and it will cost you around $350. I'm interested in how your strut bar looks and actual fit under the hood as it is very tight fit. Did you notice any difference on turning before and after the strut bar?
Well it is good to hear we are not alone in fixing up our LS.
