How to turn the camshaft pulley to match timing mark on the belt?
#46
Yeah that tool will help you hold it when you torque the bolt, (I think it's something like 80 ft lbs) and spin it but you could adjust/spin the pulley with just the bolt if ya have to. You like new/special tools, don't ya?
Why not, right?
The problem and questions you have about the cams and valves and stuff is why I bought my 93, b/c it's a non-interference. I was reading more and what I read is as long as the crank is still at 50* ATDC you can move the cams counter clockwise to get the marks to line up, which sounds right to me. So the tension you feel on it should only be the spring compressing (like deanbrown3 said)
But you should know that for sure before ya take my word on it. I know with my 93 when I spun the cam counter clockwise it took alot of force, and it was a springy force.
#47
Don't turn the cams counter clockwise. There is some resistance turning them clockwise but that is ok. Just turn them clockwise until they are back on the timing marks. An awesome idea I saw in a youtube video was using zip ties to hold the belt onto the cams once you have it on the marks so it doesn't pop off when you put tension on it while trying to get it on the crankshaft.
http://www.youtube.com/watch?v=7D_8u...feature=relmfu
#49
#50
#51
1. Do you need to drain the engine oil to change the crank seal?
2. Can you or can you not, on my 96, turn the cams clockwise any number of turns? Can you also turn them counterclockwise?
I'm just getting ready to do the 3 seals.
#52
Dean - couple of dumb questions here, to someone who seems to know what is what:
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#53
So, I can't wait for the SCH cam pulley holder to arrive.
I pried the spoke (is the name correct? learned a new word) of cam pulley wheel against the engine block with a big screw driver, tied the wheel with wires to the water inlet pipe to stop the spin of the cam pulley. I tied the timing belt to the cam pulley, then fight with the right cam pulley and the belt, and the timing belt was on.
CR mark to crank mark.
L line mark to left cam pulley mark.
R line mark to right cam pulley mark.
Will install the tensioner and rotate the engine by hand after a break and lunch (lesson learned).
Thanks every member for advice.
#54
dashan - I bought the OTC version of that cam tool, for $56, and the first time I used it one of the long pins pulled out of its thread and its fcuked. What I had to do was squeeze the tool behind the cam and then screw the pins in again from that side, so it was closer to the spokes. The tool I got can only use the long pins, since the spokes are too far inside the pulley. Hope your version is made better than mine!
