Air ride controller with modified suspension
Hey guys. I have installed an air ride controller into my ls400.
Will shorting the rods on the height sensors make it go lower or would I be wasting my time doing it?
I'm currently on stock wheels sitting on the lowest setting and am only wanting to go lower for a park setting.
you can drop the stock air all the way down, bbut you just can't drive on it if you want them to survive longer than a couple days. would have to raise up to near stock height for longevity whenever you drive.
make sure you've accessed the super low mode of the controller, dont ask me how since i don't speak japanese.
Yep super low mode is enabled. Its as low as the controller will enable.
As I said, there still seems to be a fair amount of travel in the shocks so I had assumed they could go lower. If not, I guess I will have to invest in the Youzealand kit later on.
And FYI I roll on the lowest setting and have already ticked over 10,000kms with no problems. They still work perfectly and do not leak if left parked up for extended periods.
Rotary13b
03-16-18 07:19 PM
