Advice on replacing Timing Belt and Water pump, etc. for 98 Ls400
#31
Oh well, brain fart. Sorry billy, I thought you did them
but as I sat thinking I remembered it was william somebody who had his cams out and it was only a 93.
Anyway, PjLex; here's a video of a crankshaft seal removal. (NOT a Lexus) At about 4:20 it shows how to take it (crank seal) out.
http://www.youtube.com/watch?v=bf93v-d3Kdc&feature=fvsr
#32
Thanks for the video. I got the crankshaft oil seal out and the new one in. Used a smaller screwdriver and got it out.
#33
Moving on to the LH Camshaft oil seal. Should I do the LH Camshaft oil seal? I think it is leaking from there. the RH cam looks really clean compared to the LH cam. Unless it is something else.
#34
Have you actually done the camshaft oil seal on the LH side? I was told you did. Why are you saying no? I know it is a PITA and i have got to be super careful, but is it dangerous to do it?
#35
Are you talking about me? I thought billydpowe did but it was someone else. I did mine but it's a 93 which is 100% different. Personally, I wouldn't even attempt to do the cam seals on your 98 without the service manual right in front of me b/c the cams need to be removed. I would want to know exactly which bolt has to come out in what order and which way the cams need to go back in and everything like that. On the 93 the cam seals are just like the crank seal was, easy. If I was you I would look around for some step by step. I can't emphasize that enough and I've been working on cars for over 30 years.
#37
I was responding to Billydpowe, so Sorry about that. I tried to do a direct message or something. I was just wondering why he was all no , no , no like. Sorry about that, thanks for all the advice.
I have a shop manual that I downloaded on line in pdf form. It was dead on with the timing belt / water pump job. So I think it would be good for the LH camshaft oil seal.
#38
Well I spent some time with flashlight and small mirror. And I think that the camshaft position sensor located under the LH cam cover could be leaking oil. And possibly not the camshaft oil seal in the LH.
I looked under both timing cams. Expecting to find at least some oil under the LH timing cams. To my surprise it was clean, I could see silver metal. Even right under the unit. It got a little dirty / oily directly to the right of the camshaft position sensor. The RH cam was clean and looked virtually the same way, silver metal underneath. I tried to take pics but my camera sucks.
Anyway, looking at the LH cam cover shows most of the oil leak eminating from that spot where the camshaft sensor wire comes out.
So is this possible that the camshaft sensor could be leaking oil around the timing belt?
My whole oil leak problem in the area of the timing belt could have been some water pump leak, crankshaft leak, and some oil leaking from the camshaft sensor.
So I think I can pull the sensor out, clean it up and put some liquid sealant around it and solve the problem. I am hopeful.
#39
The sensor itself doesn't have any oil in it, it's electronic and it just picks up a signal from the cam pulley. The reason it's covered with oil is b/c (I still say) the cam seal is leaking. Most of the oil coming from the seal would be behind that black metal plate behind the cam pulley. The little oil will come out the bottom of the plate, and with the timing belt spinning, the dirt and dust will stick to the oil. That's why it looks to you like the sensor leaks oil. What I would do, to see if the seal is or isn't leaking, is take off the cam pulley and that metal plate. Then you can see the seal perfectly. You might not even have to take off the plate to see the seal. I think the pulley is 4 bolts, but it will say in your manual. Do NOT spin the pulley.
#40
Deanshark , you were exactly right I removed the metal covers and found more oil leaking. Eventually had to replace the LH camshaft oil seal. And decided to go ahead and replace the other one. A double PITA sandwich. But I got it done. Thanks for all the advice everyone, especially Shark man.
I only have one question, how much do you torque the valve cover bolts when you tighten them? I have looked in the shop manual but can't find anything.
Thanks, Preston J.
Thanks, Preston J.
#42
Glad I could help and that ya got it done. About the oil leaks, I can see every tiny bit of oil on an engine. I hate a dirty engine, I feel it should be clean enough to eat off of.
Although there isn't too many that are anywhere near that clean. The valve covers get torqued to 52 in-lb. (NOT ft lbs) Don't tighten them too tight, that just crushes the gasket which will crack it and make it leak. Ya don't want that.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#44
You could just snug them tight. There's a conversion into ft lbs which comes out to only about 3 or 4 ft lbs. I'm not sure what the exact conversion is though. When I need in lbs I usually just look at the chart I have in my torque wrench case, but someone borrowed it and I didn't get it back yet.
I'm sure if ya did a Google search you can find it.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
