So let me understand this- you only need to support the transmission, not the engine, when doing this right?
Correct. I used a transmission jack with a big rubber pad placed on the trans pan. Any kind of stable support will do. When you get under there and look at that mount, it will be pretty obvious that the trans pan is where to put a support. It is plenty strong and there is not that much weight on the mount. Just use a wood or rubber block against the pan.
