93ls400 4 piston calipers
Yes, the first generation LS400 has two piston front calipers. The calipers grew slightly in size from 89-92 to the 93-94 model years. Lexus started using the four piston calipers on the 1995-2000 LS400. You can put the later LS calipers on your 93 if you change the lower ball joints. You will need the calipers, pads, shims, brake hardware, rotors, lower ball joints and caliper mounting bolts to make the swap. Also, you will need to have wheels that clear the larger calipers. I just did this modification to my 93 LS400 and it was well worth it. I am using wheels from a 2000 LS400 Platinum Edition with the machined faces and the car looks great!
Good luck!
Good luck!
apham8 (12-01-23)
aliga
17
05-06-11 10:23 PM
International F/S 96 LS400 Front Summitomo 4 Piston Aluminum Calipers
nine3es
SC400 / 300 Classifieds
04-25-11 08:55 PM
evileagle
Suspension and Brakes
12
08-28-07 07:16 PM
