Head light lens
Old 08-04-11, 05:11 PM
prb78
prb78's Avatar
Default Head light lens
I have a 1998 Ls400 and the head light lens are turning opague. It appears to be film on the outside of the lens. I hear the off-the-shelf remedies do not work.
Any ideas? I am sure someone has had the same issues and have a solution.
Thanks!
Old 08-04-11, 05:22 PM
RA40
Super Moderator
RA40's Avatar
Welcome to CL.
If the car had a clear bra applied over the lens, you can remove this film and apply another. If it is a bare lens, there are products to polish it up and remove some of the haze. The UV and wear from road grit is not easily reversed.
Post a pic up of the headlights so we have a better idea. With your post count, you will have to use an outside source to host the image and link it for us.
Old 08-04-11, 06:01 PM
Kansas
Kansas's Avatar
There have been several past threads about restoring even horrible looking plastic headlight lenses on the 98-up LS and making them look and operate like new. I used a Crystal View kit from Advance Auto several years ago: http://www.myheadlight.com/
If you use one of these lens refinishing kits do it when the air temperature is relatively cool - below 80 degrees - and do it in the shade. The last step in the Crystal View process is to apply a clear coat sealer which dries too quickly when it's hot.
I don't have "before" photos of my awful looking headlight lenses but they cleaned up very nicely with the Crystal View kit. Here are "after" photos.
Attached Thumbnails Head light lens-imgp2255.jpg   Head light lens-imgp2256.jpg
Old 08-04-11, 07:55 PM
prb78
prb78's Avatar
Thanks RA40 and Kansas for the help. I will post before and after pics later.
Best,
parker
doodoo
09-03-12 02:57 PM
ScDoinIt
SC- 1st Gen (1992-2000)
15
09-14-11 06:17 AM
tru_player
07-05-07 10:07 PM
Jmai22
GS - 1st Gen (1993-1997)
18
01-15-03 06:37 PM
subal
RX - 1st Gen (1999-2003)
08-05-01 05:09 AM
Quick Reply: Head light lens
