Negative Offset Obsession....Need Advice
Hi guys,i have a little predicament here.I drive a 1990 ls400 as in the pics and need some help on making these wheels work.They're ssr vienna kreis 19x10.5 inch wheels with an offset of negative 13.Test fitted them on my car and they poke out bout 2.5 inches which is a little too much.Have considered stretching 235/35 tires on it and cambering the wheels to the max but will still poke out too much rite?i'm unsure how much i can pull the fenders but all in all i need help on how i can pull the look off.Any advice on how i could make it work or is my negative offset obsession a little too much?
I like the clean lines and looks of the car and wouldnt like to put any widebodykit on.any suggestions?
The problem is i've always wanted a set of 19's on my car and have been searching for these wheels for quite some time and now that i've found it is in a ridiculous offset.As i live in Malaysia,these kinda wheels are quite difficult to come by and i am nt exactly spoilt for choice.Even if there are,they would be ridiculously expensive and i plan on sticking to my budget.i'm getting a good deal on these wheels so thats why i'm tryin my best to get it to fit.
The front's fit perfectly.Only the rears are the issue.I have already rolled the fenders from my previous wheel set up.
Any help or advice would be much appreciated!Thanks in advance...
Do you think that could work or will it still poke out too much?Coz the biggest negative offset i've come across on this forum is 10 inches width and negative 6 or 10.
Some have said its gonna look odd with the stock rear bumpers and sides with just a massive fender pull and flare...
I'm just afraid of pulling the fenders and not pulling off the look as its gonna be impossible to revert back to the fenders original shape.
The tire shops around here arent too keen on stretching the tires.Max stretch i can convince them to try would be 235/35's.Will that work?
Retired
ran a 10 -5 in the rear and i had 235/40 (too big of a tire) with pulled fenders. with 235/35 and pulled fenders with some camber, u should run those wheels easily. www.vipstylecars.com/forums is a helpful site and dont bother with stancenation, all crap over there.
I'm running a 19x10 -7 in the rear with -6 degrees, a massive pull and a 215/35
Still have a few mm of clearance on each side, threw my 8mm slip-on spacers on and had -15 effectively. Would run that but stacking spacers is pretty sketch with only a few mm of threads for the lug nuts.
Can you run -6 neg camber on the rears?i thought the max was -2.5 thru the lower arms?
I can only run 235/35/19's on my wheels.no one wants to try anythin smaller and honestly i'm afraid too...haha
P.S:i love the way your car looks dude...its sick.Love the color and love the stance.Dare i say,would have chosen that silver over black any day.
Hi rey and puredrifter,cant seem to access Vipstyle cars forum from here,its either down or its been blocked.can access stancenation however and will try posting up there.Thanks for the feedback guys.
Dont mind the paint as the car's due for a new paintjob at the end of the rear.Hw much bodywork are we talkin bout?
Retired
well the bodywork will help make the fenders look a look smoother.
i started off with this.
http://i254.photobucket.com/albums/h...g/IMG_0244.jpg
and ended up with this
http://i254.photobucket.com/albums/h...g/IMG_0251.jpg
the rust on the quarter panel threw off the pull but that will get fixed eventually.
Did u just use a roller to get that flare and keep adding the spacers to keep pulling and flaring?
What was the poke before you started pulling?was it s much s mine,poke of 2.5inches?
Would love to see more pics of your car dude...i'm loving it...
Retired
yea i used just a roller to get that, its not the best job but it got it done. i just kept rolling and fitting the wheel to see where it was as far as clearance.
the amount of poke is shown in the first pic i threw up. im gonna guess around 1.5-2" of poke.
one thing ur gonna experience is that on the inside of the quarter panel, theres a hump that hangs low. ur gonna need to hammer that in or its going to rub like crazy.
