outdoor temp sensor says -30 celcius!
Old 08-25-11, 06:12 PM
StevieA
StevieA's Avatar
Default outdoor temp sensor says -30 celcius!
93 LS changing lanes lightly pushing signal indicator & heard a slight "stzzzzt".Then quickly noticed my A/C stopped blowing cold. Realized my outdoor temp indicator was showing -30 celcius when it was really 27 celcius outside. Tried pulling fuses then unhooking battery terminal still no effect. Only way I can get A/C is to set at max cold. Anyone else have this problem? Do I need to replace a sensor?
Old 08-25-11, 06:17 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
sounds like something shorted in the climate control or associated circuits...?
perhaps the AC clutch or harness?
Old 08-26-11, 07:49 AM
billydpowe
billydpowe's Avatar
this might be similar to yours..
https://www.clublexus.com/forums/es3...re-sensor.html
and I am sure you have seen this, but.. http://www.lexls.com/tutorials/air/accodes.html
Old 08-26-11, 10:04 AM
deanshark
deanshark's Avatar
Try the first link that Billy posted and pull the fuse it says to for 30 seconds or more. I had that problem when I pulled my dash and changed the heater core. (-22) I pulled the fuse just to reset everything anyway and it started working correct after that. I think it also effects the signals, at least mine did, b/c mine started working again at the same time.
Old 08-27-11, 08:10 AM
StevieA
StevieA's Avatar
Thanks Guys - I love this site! Anyway, I tried pulling the DOME fuse for 30 secs and it didn't work. Bought the two day pass for TIC & doing the diagnosis it's giving code 12 Ambient Temperature Circuit. Basically it could be the ambient temperature sensor behind the bumper or a short in the harness or the air conditioner control assembly. Think I'm gonna take to Lexus for this one & hope to god its just the sensor. New sensor's about $95.
Old 08-27-11, 09:45 AM
PureDrifter
BahHumBug
before taking it in pop the hood (or check from underneath, i forget) and make sure the sensor is both plugged in/undamaged and the wiring to it hasnt been damaged.
Old 08-27-11, 10:18 AM
deanshark
deanshark's Avatar
It's from underneith. Alot of times the wires get pulled out and sometimes cut, especially if you don't have the lower engine cover. I know I've seen the sensor and the part # here somewhere but I can't find it right now. I'll look a little more incase you need it.
Old 08-27-11, 11:01 AM
deanshark
deanshark's Avatar
There's no part number on this but I found this. http://www.partswebsite.com/oemlexus...Submit=Buy+Now It's not what I remember seeing in the past but at least, if you need it, you can find it here.
Old 08-28-11, 05:23 AM
StevieA
StevieA's Avatar
Default Fixed!!!! thanks!
Hey guys thanks so much - was getting a bit lazy there. Felt down from the top & noticed one wire was broke off right at the plug. So I pulled the lower cover and got the sensor off and the plug apart. Checked the ohms on the sensor and they were in spec so now I had to fix the wires. Took it to my redneck buddy "Get-R-Done Auto". We threw away the plug with the broken wire and stole two wires and ends off an old oxygen sensor and plugged those on the bare metal ends of the sensor and filled up the hole around the oxygen sensor plugs where the old plug was with silicone and let it dry overnight. Then this morning soldered and heat shrunk the wires together & reassembled everything and it still said -30 C. So I pulled the DOME fuse for 30 seconds and voila - system works again!
Total cost $21.95 for a case of beer
Love this site!
Old 08-28-11, 06:16 AM
deanshark
deanshark's Avatar
Love this site!
Oh yeah, gotta love the mechanics that work for alcohol. As long as they drink it after working on your car.
Cthopkinsc
Performance & Maintenance
04-22-16 07:35 PM
jlawr
07-31-15 12:47 PM
DONT SLEEP
SC- 1st Gen (1992-2000)
07-28-10 06:15 PM
cgreenberg
06-12-10 04:58 AM
Quick Reply: outdoor temp sensor says -30 celcius!
