1993 ls400
Old 08-27-11, 03:40 PM
dspete
dspete's Avatar
Default 1993 ls400
My LS400 is a 1993 with 147,XXX miles on it. Just changed the oil. What else should I change on it. I will assume nothing has been done. Tune up, sensors, thermostat i dont know. Help!!
Old 08-27-11, 03:50 PM
LiCelsior
Retired
LiCelsior's Avatar
air filter, spark plugs, spark plug wires, distributor cap, distributor rotor, coolant temperature sensor, fuel filter, o2 sensors, coolant, and thats about it.
Old 08-27-11, 08:12 PM
Garage7RP
Garage7RP's Avatar
Timing belt.
Old 08-29-11, 08:36 AM
LiCelsior
Retired
LiCelsior's Avatar
oh right, timing belt, water pump, tensioners, idlers.
Old 08-29-11, 09:07 AM
Rey
Rey's Avatar
dont forget trans and diff fluid. Thats only mechanical. You need to assess whether your suspension is still good or not.
Old 08-29-11, 03:58 PM
dspete
dspete's Avatar
Thank you so much. Not much of a mechanic...so will this cost me alot?
Old 08-29-11, 04:18 PM
vaughn37
vaughn37's Avatar
personally I would check your timing belt if it doesn't look bad leave it alone... if something isn't broke don't mess with it.. my car has the original timing belt and i have 180 plus thousand miles on my car....my spark plug wires are original and have low resistance still.
the motor isn't a interference motor so if the timing belt does break it will only leave you stranded
Old 08-29-11, 04:19 PM
vaughn37
vaughn37's Avatar
your talking big money if you let the dealer do them things.. thousands
Old 08-29-11, 04:21 PM
LiCelsior
Retired
LiCelsior's Avatar
whats listed above, probably 6-800 in parts alone.
Old 08-29-11, 07:29 PM
chalels40o
chalels40o's Avatar
just do a basic tune up for now do all tat stuff later
Old 08-29-11, 08:47 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
and what will that help exactly?
Old 09-05-11, 09:43 AM
dspete
dspete's Avatar
Default Ls 400
Thank you once again.....Everything is running good except for spuddering when I excelerate. What's that all about?
Old 09-05-11, 10:10 AM
deanshark
deanshark's Avatar
The "spuddering" can be a number of different things. Have you done anything to the car yet, other then the oil change? The spuddering is either fuel or ignition related so the most common parts to change would be fuel filter, spark plugs, spark plug wires, distributor caps and rotors (2), and ECT (Engine Coolant Temp sensor) That's the common "tune-up". Changing the timing belt will not make your car run any better unless it jumped time. If it jumped, the car would be running really rough like a bad skip.
You say "Not much of a mechanic...so will this cost me alot". Cost will determine on how much of this you can do yourself. http://www.lexls.com/tutorials/ has the tutorials you need to do most of the work. If you can twist a wrench, get dirty, and follow directions then you'll save a bundle of cash. If you can't then the shop will wack you on the labor charges and raise the price on parts. (They need to make money too) How much of a mechanic are you?
Old 09-05-11, 12:09 PM
GKLCPA
GKLCPA's Avatar
Ditto on Deanshark and if you go through that stuff and still have sputtering, you should check the fuel pumps and the fuel tank. I have an older BMW 535 that recently had a sputtering issue and it turned out to be a rusty tank from gas having sat in it for 10 years. I had to wind up replacing the tank and the fuel filter
Having older cars like these is only cost effective if you can do some of the work yourself.
amanda
11-01-12 08:47 AM
TechGreek
SC- 1st Gen (1992-2000)
03-08-11 06:32 AM
chippern73
Maintenance
03-11-10 11:05 PM
LexusPhan
08-21-09 05:45 PM
Banshee365
Maintenance
11-28-06 09:46 AM
Quick Reply: 1993 ls400
